Last Post: Deimus
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Track Bike Build
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 4 Weeks Ago
Old Junk Old Junk is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1971
Other Motorcycle Model: XLCR Tribute
Other Motorcycle Year: 1980
Old Junk is an unknown quantity at this point
Default Anyone know who can shorten fork tubes?
One and all,
In the past I took a couple of bargain ebay finds to Frank's Forks/Forking By Frank in nearby Evanston, IL to have them cut some 8" over and 10" 33.4mm fork tubes to the stock length. They did a great job. Good price and rapid turnaround.
I've had another 33.4mm fork set for a few years now that needs to get cut to size. Frank's seems to be MIA. Frank's Forks closed at the Evanston, IL, said they intended to reopen.
Over the YEARS since their Evanston closing, I've tried leaving emails to see if they're open. When I call their voice mail box is alway full. Now they're supposedly in Mississippi with an opening date of July 01, 2021.
Seems like maybe they're not a going concern anymore. Does anyone know?
If Frank's isn't open anymore, does anyone have a reliable source to cut/machine some fork tubes to standard spec? Good suggestions appreciated.
Old 4 Weeks Ago
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: 1968 XLCH
Other Motorcycle Model: '89 FXRS, '73 R50/5
Other Motorcycle Year: '89
Fivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant future
Most any machine shop with a lathe.
Old 4 Weeks Ago
Looks like they are a wee bit late on their re-opening......
I hate to loose a resource like that.
Old 4 Weeks Ago
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1988 BMW K75
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
Franks is truly the best for fork tubes. Sad to hear they might be gone. They seemed to be unwilling to modernize. The last time I purchased from them just a couple of years ago they didn't communicate via email and the only payment method was COD delivery.
Old 4 Weeks Ago
smokey 2 smokey 2 is offline
Sportster/Buell Model: 1970 XLCH
Sportster/Buell Year: 1970
Other Motorcycle Model: Ultra Classic
smokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of light
Last time I checked Custom Cycle Engineering in Oceanside Ca. was still making
fork tubes.
WORK TO RIDE, RIDE TO WORK
Old 4 Weeks Ago
forqueue forqueue is offline
Sportster/Buell Year: 1976
forqueue has disabled reputation
They were carring-on conversations on Facebook as late as last week. You need to log-in to see more than their home-page.
https://www.facebook.com/FranksForks/
Hi! I'm looking for stock tubes for a 1980 Honda cb750c. That would really put the icing on the cake for me for this bobber project i have going.
· Reply · 1w
Author
Franks Forks
Hi Michael, Yes we can make a set for you. $375.
· Reply · 1w
