0 Dragging clutch
Last Post: Ark OB
0 Starter Relay?
Last Post: andy2175m4
0 Oil pressure switch
0 Carb ???
Last Post: mikethebike61
0 Video - FEED THE BEAST - Your Harley Will LOVE This Mod!
0 Deeded Electrical
0 It's Glamazon's Birthday!
0 What oil temp do you run
0 need help with 68 XLH
  #91
Old 26th January 2011
Big_e78 Big_e78 is offline
Sportster/Buell Year: 1968
Big_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enough
This bearing separator and gear puller set has worked for everthing I've come across so far, though I haven't pulled this particular one. I even rigged it up to press my flywheels out of the case.
http://www.harborfreight.com/14-piec...set-30305.html
Old 27th January 2011
hogmania hogmania is offline
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1977
hogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura about
Yes a bearing separator is the best thing to use on timken type bearings, has always worked for me.
Old 16th February 2011
fergerburger's Avatar
fergerburger fergerburger is offline
Senior Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of light
Default Special tools
Here is my new countershaft bearing setting tool. I cut it tonight to set the depth and install the countershaft bearing. I center drilled and tapped it to accept an extension OR just use it as a press tool. I shouldered it to set the depth correctly for the oiling channel
Crazyspeed's Avatar
Crazyspeed Crazyspeed is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1979
Sportster/Buell Model #2: Moto Guzzi Griso
Other Motorcycle Model: Moto Guzzi V7 sport
Other Motorcycle Year: '73
Crazyspeed is on a distinguished roadCrazyspeed is on a distinguished roadCrazyspeed is on a distinguished roadCrazyspeed is on a distinguished roadCrazyspeed is on a distinguished road
Originally Posted by Shadowdog500 View Post
We are starting to have photos and videos disappear off of this thread. Any reccomendations on where to put these photos so they dont go away in the future?
Are the Member galleries permanent? Is there a central gallery on this forum to store stuff like this?
Chris
Ya, what he said
CRAZYSPEED
NAFORD302's Avatar
NAFORD302 NAFORD302 is offline
Other Motorcycle Model: HERITAGE SOFT TAIL
Other Motorcycle Year: 88
NAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura aboutNAFORD302 has a spectacular aura about
Thanks for all the info and pics this is very good
Old 17th February 2011
bigmurphdog33 bigmurphdog33 is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
bigmurphdog33 is an unknown quantity at this point
Originally Posted by dobermandave View Post
I just used an old point plate & welded a 1/2 X 13 nut in the center. Just used a 1/2 X 13 bolt to ease the cover off with the 3" headless bolts Mick suggested. This way the #2 cam stays in place so they don't all fall out.
didnt use something like that... they all fell out!!!
Y BUY WUT U CAN BUILD!
Old 12th March 2011
zipdog zipdog is offline
zipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to beholdzipdog is a splendid one to behold
Default Clutch Tool
During a recent clutch rebuild, I made up a rig like the one Hopper devised in the first post of this thread. Now that I'm through with the "tool" and have discarded it, I want to make a more permanent one like the commercial versions, but needless to say, I neglected to record the dimensions between the upper left and lower right 1/4-20 holes in the primary. I THINK I remember 10 1/8", but can't be sure. Does anyone happen to have that dimension or have the primary cover off and could get it for me? Also, I seem to recall that the center hole in the tool is not exactly in the center, but 5 1/2" from the upper left hole. Any help would be appreciated.
Rusty
Old 12th March 2011
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond repute
You did not search hard enough!!!
http://xlforum.net/forums/s...and+made+tools
Patrick
Flat Head Forever
Old 12th March 2011
THANKING YOU, PATRICK!!!!!!! I thought I did a thorough search of that thread.
Is this a great site, or what? I just got my '81 bobber on the road after almost a year.
Rusty
PS: Any other over-60 Ironhead riders out there?
Old 12th March 2011
I am... Went 60 in Jan...
