Last Post: Porkchop9
Last Post: fafcpa
0 Indicators not flashing
Last Post: Gravitas
0 1982 rubber oil hoses
Last Post: Gravitas
0 Gear indicator missing
Last Post: Shahyaan
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
0 75 XLH Bendix Carb Spitting Gas - Video
Last Post: jibber
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
  #191
Old 30th May 2020
Sportster/Buell Year #2: '03
Originally Posted by CanadianTux View Post
So many awesome ideas and tips in here! Such an amazing resource. THANKS to everyone who has contributed!
I had a brief look through the pages and did a search but I couldn't find anything about a homemade "Fork Spring Retainer & Pin Wrench" OEM 94694-52.
Has anyone had any luck getting their fork spring retainers out with out this tool?
I'm rebuilding my front forks and this little step has got me stumped.
Any ideas?
put an allen wrench in each hole [2],put a,box or open end wrench,between them,turn. if they're not frozen,this will work.
i had my forks apart again this week.a pair of needlenose pliers works even better for the fork spring retainers.
Old 31st May 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
You will run across spring retainers that are VERY stubborn.
I have even broken the removal tool trying to get some out.
I have had to apply heat to the tubes and hold them in a vice while swinging on a 1/2 drive socket to shift them
Clean the threads out as well as you can before you remove them. These ere a fine pitch and easily bunged up and damaged.
Put them vertical in a vice and pour a little penetrating oil in and allow plenty of time for it to work down.
These are possibly the worst designed forks I have ever worked on. Luckily, the provide little actual movement, suffer unduly from worn bushes, have no real damping to speak of and a fairly liner spring rate. Also, they are too weak for the job. Too small a diameter and to thin wall tubing means that if you do manage to get the brake working to 100% of it's capacity the forks will twist under braking.
So, they suit the rest of the bike perfectly.
