0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
  #31
Old 2nd January 2009
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Default Generator gear puller tool
Here is a nifty little two-leg puller from the local auto parts store that gets the gear off the generator. (Take the nut and oil slinger washer off first - this pic is just mocked up for demonstration!)
You have to be sure the puller legs have the thin hooks on the end that will get in behind the gear.
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond repute
OK, here 're some more hand made tools...
52/71 dry clutch locking tool, driver/driven plates bolted/welded together (bolts are there not to hold them together, just for pulling out afterwards!!!):
72 and later wet clutch, same idea:
"Spider" to improve wet clutch parallel throw out while installed, allows individual nut adjustment:
Patrick
Flat Head Forever
Slotted hand grinder spanner to tighten left hand side swing arm big nut, the one hidden behind clutch:
Patrick
Now, a few factory tools that are worth buying if you find them. I've put their part numbers as well if you want to google them:
Rod locking tool, fit on the cases, H-D 95952-33:
Shaft extention and inner Timken extractor, H-D 96015-56:
Tappet block extractor, needs the cams to be still in the cases, H-D 95724-57:
Dry clutch hub puller, H-D 95960-52A:
Patrick
jakazz's Avatar
jakazz jakazz is offline
Sportster/Buell Model: 1200
Other Motorcycle Model: hd nightrain
Other Motorcycle Year: 2007
jakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura aboutjakazz has a spectacular aura about
This should def be stickied
07 FXSTB-VH stepped drags-PC3-SMW Testament Wheels,18x5.5,18x3.0, 200x18, 120x21, Metzler 880, Zyndall z-pads on PM discs
Oh and 2 sporty projects ongoing, 2000-1200, and a 94-883
Old 5th February 2009
Hopper's Avatar
Not home made but one of the handiest gadgets I have bought is this sport bike rear stand from the local riceburner shop. Handy for chain lube, tire changes etc as well as when you just want the bike standing up vertical and not leaning over while you work on it or change oil etc.
The two hooks that are desigened to fit over special bobbins bolted to a modern sportbike swingarm fit just perfect on to the bottom shock/footpeg mounts on the Sportster.
Hopper's Avatar
Default Clutch spring compressor tool
Fron another thread here is 72 Ironhead XLH's suggested modification to FrenchOwl's excellent clutch tool so it can be used to pull the hub too, a bit more sophisticated than my piece of wood from an old lawn chair.
Originally Posted by 72 Ironhead XLH View Post
Mine is similiar but added 2 additional holes to use it on the clutch hub also,and slotted the area for the case screws
Gone Gone is offline
Gone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud of
WOW, i stumbled on this section, this is great.
Old 17th February 2009
Link to some more home-makeable tools:
http://www.ironheadcycle.com/pages/tools1.htm
Old 1st May 2009
Hopper's Avatar
Default Carb removal rig - without removing horn or ignition switch
I posted this an answwer to another thread, but figure it could be handy here for the record:
I am just too damn lazy to take my horn and ignition switch off, let alone my gas tank. So I came up with a simple rig that allows me to get in and unbolt the carb on my 77 without removing anything else.
It is a 3/8 ratchtet handle with a 4" extension, universal joint (the type with a spring around it to hold it straightish) and a 1/2" AF deep socket.
It will slide straight in to the top carb stud nut.
It will slide straight in to the bottom carb stud nut if you hold the horn to one side, it flexes on its rubber mounts.
The rig:
Into the top stud
Into the bottom stud.
And like Mick said, don't overtighten. You will bend the flange on the carb into a nice bow that will not seal until you file it flat again. I hold the 3/8 drive handle up close to the head for minimum leverage and just "nip" the nuts up lightly. Never had them come loose or leak.
