Last Post: 4cam
0 help with stuck engine
0 First start question
Last Post: mac93
0 Starter Relay?
5 Rethinking 1250 Build
Last Post: Desertfox
Last Post: Fivecats
Last Post: lehel
0 Sportster R.I.P.
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: speedyrette
Last Post: 99-883-c
0 1982 rubber oil hoses
Last Post: Gravitas
Old 3rd August 2021
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud of
Default clutch gear change out
My indie says he'd probably go with the clutch gear I have, but I think the dogs look a little rounded over. I'd like to change it while I have the door out. He did put a new bearing in it when he fitted the door to the crank case.
I have a 1 ton arbor press and wondered if this is a job I could do, or should I have it done for me? Any special tricks or procedure?
Stop by my build thread:
http://xlforum.net/forums/showthread.php?t=2076933
Four wheels move the body. Two wheels move the soul. Three wheels move the bowels.
Old 3rd August 2021
doodah man's Avatar
You can do this easily - it’s a minor interference fit between clutch gear and trap door bearing. Make sure to support the inner race so as not to put a load on the trap door snap ring and ring land.
Old 3rd August 2021
No heat needed?
Old 3rd August 2021
Sportster/Buell Year #2: '03
not needed...although i did use a bottle jack press.
Old 3rd August 2021
thanks guys
Old 4th August 2021
doodah man's Avatar
Your one ton arbor press is the perfect tool for the job.
Old 4th August 2021
Good. Now I just have to get over the sticker shock for an Andrews gear.
Somebody on ebay has a supposed NOS one but there's no packaging with it and there's no reason it's not a V-Twin one imo.
Old 4th August 2021
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Sticker shock on an XL trans??? Just compare cost to a case repair. That will get you over that.
Old 4th August 2021
an Andrews gear or a clutch gear? the gears are fairly easy to recognize without packaging.post an ebay link.
Old 4th August 2021
ferretface's Avatar
Sportster/Buell Year: 1983
ferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant future
I don't know what you have (bike or $$$) but this is actually a great deal...
https://www.ebay.com/itm/334101720247
Andrews 4-Speed Gear Set for Sportster For Harley-Davidson 250301 DS-194511
US $735.81 FREE Economy Shipping
All of old. Nothing else ever. Ever tried. Ever failed. No matter. Try again. Fail again. Fail better. -- Samuel Beckett
