0 It's doodah man's Birthday!
0 Both of my Sportsters going to the auction now
0 WTB: Factory Ironhead 2-1 Head Pipes
Last Post: Villageidiot
0 Anyone still successfully running Shinko 777 170/70/16 ?
Last Post: Adam76
0 Was purring like a kitten, now this happens (not starting)
Last Post: maverick31210
0 Bendix / Zenith questions
Last Post: The Doctor71
0 ParrotHead's on the road again
Last Post: oupa
10 Future hardtail springer.
Last Post: Yakcm2
0 Is this stock?
0 Went just a little darker
Last Post: Yakcm2
0 Further Forward Mid Controls: Shifter Too High Or Too Low
Last Post: stevej5
Last Post: koolbreeze
0 Sportsterpedia Progress
0 Wtf?
Last Post: Akdawg
0 Spark Plug
Last Post: gpydeski
0 New stuff from Harely
Last Post: oupa
0 To wheel or not to wheel
0 Cam Cover Swap Question
Last Post: alrbarton
7 Starter Problems???
Last Post: Tucsonmax1
0 Do you like Brazilians???
Old 29th February 2016
davesz1r's Avatar
davesz1r davesz1r is offline
Sportster/Buell Model: xlh 883 hugger
Other Motorcycle Model: kz1000 z1r
Other Motorcycle Year: 1978
davesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to behold
Yes autometer has one that will work, I used one for awhile. costs more and fell apart! the stewart warner is very simple to hook up. three wires, key hot. ground and tach to neg. side of coil.
1275 cc 10.54:1 cr se heads .560 cams hsr42 dyna 2000p patriot defender 11.63@ 115 1/4
thumper87 thumper87 is offline
thumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nicethumper87 is just really nice
Would I wire the tach to my ignition tach wire or go to the coil? For $65 I think I will give it a go.
davesz1r's Avatar
I have used both the tach wire on my dyna 2000p and the neg side of the coil works fine either way.
Old 17th April 2018
Ghostdog's Avatar
Ghostdog Ghostdog is offline
Sportster/Buell Model: Sportster iron 883>1275
Sportster/Buell Year: 2016
Ghostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really niceGhostdog is just really nice
I use a stewart warner 114919 digital tach with shift lite. works great and is only $65.00 on ebay.
Hey Dave , any idea if I could wire up a Stewart warner tach shift light on my 2016 iron ? Any chance you or anyone would be able to show a step by step somehow? I’ve never really wired anything more than a new headlight bulb . Thanks
Ghostdog 2016 iron883<1275 Hammer prefomance kit, energy one extra plate clutch, 15percent spring,N4 cams, ported 883 heads ,danmoto 2-1 exaughst ,Dynojet powervision tuner .
Old 17th April 2018
Vohnsen Vohnsen is offline
i run tach right now.. but i plan on getting a shift light.. the stewart warner one are the blue one bright enough?
seems like a good price!
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
Old 18th April 2018
cycowrencher's Avatar
I run the blue one, it is plenty bright.
Old 19th April 2018
aiight cheers mate... i will grab one of ebay!
