0 Need recommendations for 17"/18" Wheels (or maybe 19..)
0 WTF Happened
0 Forum problems???
0 1979 XLH Carb
0 Hard to shift
0 Horseshoe Oil tanks repo China?
Last Post: Tyler Lillie
0 New Fork Springs
Last Post: 1Scooter
0 Hello from Germany
Last Post: priell3
0 magnetos 101 questions
0 Who's still riding???
0 Howdy All
Last Post: Texassporty06
Last Post: davixlrtt
0 Piston size id?
0 Help to ID 1974 Sportster XLCH custom parts
0 Sidebar Off
0 Electronics location 97 evo sporty
0 1200 kit coversion with 50k miles?
Last Post: Blue Scoot
0 Let's study the 77-85 oil pump, parts, and changes and when.
0 Short clip of my XR1200 in my driveway
Last Post: priell3
5 Run/Turn/Brake light problems
Last Post: Meko1250
Last Post: Jason's Sporty
0 Service interval on all rubber brake components
hubbinator (70), sport53 (66), kship (54), jrmkel (40), IR88n3 (35), waltweezy45 (32), lumberjack (29)
Old 24th November 2017
Zooker89 Zooker89 is offline
Sportster/Buell Model: Hugger
Zooker89 is an unknown quantity at this point
Default Zooker's winter build
So, here is the beginning of my 01 sportster build. I am starting with a 883 Hugger. This pic is where it sits now (actually a few days ago). I already did a few things so I could ride it for the end of the season as seen in this pic, but most will be changed again. I am just getting started on this and with imagrr. Hopefully my pic will show up.
So, the pic worked...
This next pic shows the bike with a 2.4 gal. sporty tank from T.C. Bros. I wanted a smaller tank with a cleaner look. This tank is raw steel and will get paint later on.
Now we get to cutting. The stock rear fender got shortened quite a bit. You will also notice the shocks are gone and yes, those are plywood struts to mimic the size of the slammer shocks I plan to use.
I won't be running a front fender, ever, so I am cleaning up the fork tubes.
stage one:
stage two:
While doing some trimming, I will be removing the fork lock from both the bottom tree and the frame. These picks are of the frame. I need to get a better pic of the bottom tree. It will get proper paint later.
now you see it:
now you don't:
Old 26th November 2017
I got the front end reassembled this morning. I was originally going to paint the headlight eyebrow and the wheels too, but I think I like the little touch of chrome, so they will likely stay. The bars are 12" and internally wired.
Old 3rd December 2017
I ended up breaking one of the exhaust studs off in the rear jug. I was able to drill it out almost on center and re-tap it. Here I just have a piece of 1/4-20 threaded rod in it. What a PIA that was. At least it was only one of them.
I also got the fender streets cut off, smoothed out and painted. I can't wait to get the real shocks on there.
Old 10th December 2017
Today I got to squirt some paint on the rear fender. It is rattle can satin and I will put a satin black graphic on before protecting it with a satin 2K clear.
Jheitt's Avatar
Jheitt Jheitt is offline
Sportster/Buell Model: XL883c
Other Motorcycle Model: Honda rebel 300
Other Motorcycle Year: 2018
Jheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud of
I dig it
Sent from my SM-G930W8 using Tapatalk
