0 93 883 Key switch and lighting
0 2015 883 with S&S 1200 conversion kit
Last Post: doc martin
Last Post: bklyngeezer
0 Needing help with a 99 1200S electrical/ignition problem
Last Post: CCC
0 99 1200S Sport ignition troubleshooting
Last Post: CCC
0 Riding music
Last Post: XL1275
0 Significant exhaust pop at idle.
Last Post: firevf06
0 Cobra NH slipons
Last Post: Skeezix
0 clean spark plug
0 21 vs 22 vs 23 teeth sprocket
0 Carb fastening screw size?
0 05 carb rebuild no start
0 Accelerator nozzle and idle not right
0 The salty debate thread.
0 Hello New in the Forum
0 Starting bike after 6 year hiatus
Last Post: darwin-t
0 Kick starter resistance
Old 6 Days Ago
Mike1nw Mike1nw is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Suzook Burgman 400/ 2008
Mike1nw is an unknown quantity at this point
Default Sportster engine wt.
What is weight of engine approx.?
Can you lift it out by holding at the bottom of the jugs (using a winch and a helper)?
Old 6 Days Ago
XL1275 XL1275 is offline
XL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud of
Sure after you strip a bunch down. What is your purpose? Complete engine swap? Most just get all the top end stuff off to clear the frame, wiring harnesses etc before pulling the lower. Plus it makes it lighter and less clumsy as you work down.
Old 5 Days Ago
Purpose: take to the shop.
I unfortunately broke off a critical part... no details until I recover mentally.
So, do you know the weight of this beast?
200? 250? 300? Just trying to get an idea.
I'd rather not mess with the top end.
Old 5 Days Ago
I've not done it, but it is suggested to lay the frame/engine on the side & unbolt the frame from the engine (properly supported, of course)...
Old 5 Days Ago
haven't done the evo but the iron is not that hard and i can handle the weight myself. one tip: make sure you wash it as an oily surface will make a laughing stock out of you especially if it hits your foot.
you are looking around 180 at the most, probably a tad less. to get it out the frame, i use an over head chain foil for more control. that way you can angle the engine and or frame.
if you are doing an iron with the spur oil pump, bird in hand, mod the frame so the pump can be services without unbolting the engine.
Old 5 Days Ago
Should be something on youtube to assist
Old 5 Days Ago
Sportster/Buell Year: 1974
Figure on approximately 200 pounds. If my memory is correct a kickstart ironhead complete with generator is about that. An evo with the aluminum top end may be less?
http://xlforum.net/forums/showpost.p...81&postcount=8
Old 3 Days Ago
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
When Hammer built my 90", I tore the engine down to remove, but it was completely built, except for the primary on assembly. If I remember correctly, I used a strap and winch to get it close, then muscled it into final place. A second set of hands would have helped.
I would guess in the ~200 lb category, but really no idea.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 3 Days Ago
Evo Sportster engines pre-2016?, the 1200cc weighs 12 lbs less than the 883cc. 2016? on, they started casting 1200cc cyl. separate instead of boring the 883 cyl. so they can use less material on the 883. That's all I know. Engine weight varies due to chrome or non-chrome, but 180-200 lbs is the consensus. The more parts you take off the lighter it will be....
Old 3 Days Ago
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Think of picking up an average male human that is still alive.
The dead are right out.
