0 Ideal RPM
Last Post: toe
Last Post: sprink
Last Post: CCC
Last Post: AKL1
0 Sportster Sport 1200S '98-'03 Ignition Replacement
Last Post: CCC
Last Post: webman94
0 1979 xlh brake pedal woes
Last Post: 1200CustomHD
0 Hurricanes
0 2013 48 what would you update first?
0 Hello from Home of HD
0 What Marker Lights Are These?
Last Post: FiftySixer
0 Post your paint questions here!!!!!
0 Turbo Iron 883
Last Post: Cj_
0 Wanted (Buell Inlet Manifold)
Last Post: maltesefalcon
0 KR style bolt on hard tail for 78 XLCH
Last Post: DirtyHarry68
Last Post: Diogenes415
DaddyJay, sixshooter (73), cartoad2001 (71), Dirty Ernie (65), ncpickman (59), bri1200c (57), pquirk (54), GOTWA (51), gremlinsteve (51), lbowles2 (49), Guess (41), rnaway22es, landon283 (32)
883, final drive, ratio, sprocket
FrankGS FrankGS is offline
Sportster/Buell Model: XLH 883/1200
Sportster/Buell Year: 1986
FrankGS is an unknown quantity at this point
Default 21 vs 22 vs 23 teeth sprocket
Ok I know that this topic has probably been addressed in other threads but, as much as I have searched in the forum, I have not read any posts that also indicate the solution to the question (or simply I'm not able to find them).
My 1986 883 seems to be the model with the highest ratios. Now it is 1200 cc, Edelbrock heads, Andrews V4, Super E: all this, combined with the original ratios, means that I can start from a standstill in second gear without problems.
At 70 mph the engine screams (I don't have the tachometer - soon to be installed - but I suppose it turns between 3500 and 4000 rpm) while in first gear I can tackle a 30% slope uphill with the engine almost idle.
And, of course, the bike does no more than 30 mpg (70% city, 30% freeway).
Obviously, the final ratio must be changed: the minimum is to change the final drive sprocket with the one with 22 teeth, however, may it be worth going directly to 23?
Have any of you tried and verified the differences in terms of revs in fourth gear with a 22 or a 23 teeth sprocket?
Thank you.
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud of
The difference in RPM, in any & all gears, is the ratio of old teeth ÷ new teeth.
So, basically, 21/23=0.91, that means that given the same speed, with a 23 teeth sprocket the rpm are 9% less than with a 21 teeth?
Cool, I wonder what kind of impact could this have on the acceleration.
XL1275 XL1275 is online now
XL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud of
Yes, and 1200s have different primary ratios too. Not sure about your year though.
It seems they are the same: http://sportsterpedia.com/doku.php/t...o:transfinal01
Yep, I have an 07 so that was what was on my mind. Sorry.
Torque in all gears is reduced by the same amount, the engine "feels" smaller. It only really matters in 1st, since in the upper gears you can downshift as needed. Theoretical top speed is increased by new ÷ old.
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
On Ironheads, 1 extra tooth on the drive sprocket will lower RPMs at any given speed by about 150-200 in fourth gear. I don't have a chart for any other models unfortunately.
This is not possible,.
juzyHD's Avatar
juzyHD juzyHD is online now
Master Bike Builder
Sportster/Buell Model: sportster 1200
juzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond repute
I made some calculations, I just have to find that sheet of paper. I'll post when I find it!
