0 A little MARKET RESEARCH on Skid Plates
Last Post: Andy56
0 Newbie
0 50 years of wins, the XR750
Last Post: rocketnorton
0 Stuck #2cam
0 KBS tank sealer
0 Diaphram pressure plate
0 Tools
0 carbs?
0 Zippers 1250 kit
0 100 vs 110 front tire
Last Post: wolfryder
Last Post: paulc
Last Post: dodgetrucken
0 MS rollers way too tight
0 -65A mufflers
Last Post: RussW
0 Brake light issues
Last Post: 45Brit
0 82 XLH struggling for power
Last Post: darkgizzard
Last Post: jon1966uk
0 Better Brakes
Old 9th November 2019
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Originally Posted by rejeanprimeau View Post
Take a mirror and look at your lifter roller, you need about 0.05 inches shoulder for the roller to sit on the cam, the rest can go in the scrap bin. I use a lathe to do it.
You turned the cam on the lathe, or the roller? If it was the lobe, did the machining affect the surface hardness (or am I thinking too much). A little off the lobe would mean less off the case.
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I had to take some off the lobes. That was 5yrs ago. Used a bench grinder.
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant future
I clearanced the cases with a dremel with the motor assembled and in the frame. Spent more time with the masking tape than it took to do the grinding in the cases. Tried the dremel on the cam lobes, but that would have taken all day. Bench grinder was the way to go on the cam lobes.
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
The side of the cam lobe. If you grind, tape up the lobe where the roller rides and tape it very well. One slip up...
Before you grind any lobe, I’d mock it up, cam and lifter, rotate it marked up with some Prussian blue paste or gear marking compound, etc... and be certain where the lifter roller rides.
As long as you go slow with grinding and keep it cool, it should be fine. Cutting with a lathe won’t change anything... unless the operator is an animal.
rejeanprimeau's Avatar
You machine the cam. Hold the cam on the shoulders gear side. Remove a bit of the corner or the full face of the lobe, your choice. You can also clearance with a grinders, just make sure you use a fine wheel and keep it cool.
cxf's Avatar
cxf cxf is offline
Sportster/Buell Year: 1985
Other Motorcycle Model: cb450
Other Motorcycle Year: 1974
cxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of lightcxf is a glorious beacon of light
Looks like you have found your answer and you don't need me to search for my buried Qs?
Correct, sir. Thank you very much for the offer, though.
Old 23rd November 2019
Sportster/Buell Year: 1969
RicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud of
Things you don't know until your knee deep in it. Stick to the planned outcome. Fabrication and modifications can be intimidating but in reality there's nothing that can't be built. Grind on!
Old 24th November 2019
Thanks for the encouragement. Thing is, the cam clearancing is the least challenging part of this engine build. I just wasn’t expecting it and was caught off guard. Now clearancing the cylinders for pushrod tubes, and making custom length pushrods is occupying my time. Once the cases are apart again, I’ll deal with the cam chest.
