0 Stuck #2cam
0 KBS tank sealer
0 Diaphram pressure plate
0 Tools
Last Post: mikethebike61
0 Newbie
Last Post: BitterOldMan
0 A little MARKET RESEARCH on Skid Plates
Last Post: 45Brit
0 carbs?
0 Zippers 1250 kit
0 100 vs 110 front tire
Last Post: wolfryder
Last Post: dodgetrucken
0 MS rollers way too tight
0 -65A mufflers
Last Post: RussW
0 Brake light issues
Last Post: 45Brit
0 82 XLH struggling for power
Last Post: darkgizzard
Last Post: jon1966uk
0 50 years of wins, the XR750
0 Better Brakes
Old 8th February 2013
Not valve grinding compound - toothpaste
CHOPTOP37 CHOPTOP37 is offline
Sportster/Buell Model: XLC
Sportster/Buell Year: 1972
CHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of light
A little ot...is this the same thing that made the early so sensitive to flooding during "street duty"..are the early b's susseptable to this too?...
what circuts are so sensitive to float level?
or does it have more to do with the float drop?
Rigaman Rigaman is offline
Rigaman is an unknown quantity at this point
So I should use toothpaste? or lapping compound? Or machine it?
DR DICK's Avatar
DR DICK DR DICK is offline
wont work.
will embed in the brass seat and rip up the needle real fast.
Or machine it?
the prob isnt a faulty seal, its the wrong seal angle that wears in the needle. the needle needs to be reprofiled.
ill post pics tonite.
D.D._____________________________-o&o____________________________
DR DICK's Avatar
i know you been waiting patiently. and ive been workin on it.
ill get into this a bit tonite.
Ha... whats time?
I was just curious cuz i know the bowl setting is pretty crucial to reliable starting. theres a few emulsion/air holes i always wondered if they got affected.
Old 9th February 2013
thank's,D.D. i,thought that float needle looked familiar. went to look for one on my part's shelf in the basement,last night,but was'nt dressed for the cold. bad new's is i'repaced it with the rubber tip. i,keep all my old part's,so i,know i,still have it.
DR DICK's Avatar
Ha... whats time?
float level really means fuel level.
we are gonna get pretty deep into the the interaction of all things that happen in the super b.
after years of experimentation with these carbs one thing i found is fuel level and the things that effect it, is extremely pertinent to all metering. more than any other parameter.
metering is part of gettin great ALL AROUND street performance, but it aint the whole story.
after we got a good grasp of how the super does what it does we can compare it to the early and L. the design of those adds some desirable straight line acceleration characteristics the supers lack. on the other hand those characteristics can make the side bowl carbs a bit flighty over lots of miles.
the one thing about the super is its rock solid ability to hold tune over many many miles. take this thread as an example.
how may decades for this wear problem to show?
and by rigaman's own words- ive never had any probs with this carb. it has allways run great.
i wouldt be surprised if this carb is over 30 yrs old and hasnt ever been "rebuilt". i wouldnt be surprised at all.
now if you can get L series performance from it, then its a big win-win.
and you can. but you need to play with things that if not 'quite rite' will bite you hard.
DR DICK's Avatar
heres the machining info.
machining a steeper angle than the orig will usually allow needle to reseat in the worn seat without the need for playing with the seat fitting. if you go with the orig 30 degree and/or cut the brass seat-- the needle can drop too much.
then to get float tang to needle geometery correct again the seat needs to be cut at bowl contact face. this can get time consuming. time is money at machine shop.
DR DICK's Avatar
the 3 different setups
the floats are the same early and mid.
but the early float tangs are bent in an arc so as to be close fitting to the needle groove. mid is flat. the close fit lifts the needle with virtually no tang to groove lash.
the needles and seats.
the mid had two different seats.
the inlet bores.
the mid and the late seats look the same. but the lates are shorter on the bowl side extension.
