Last Post: dodgetrucken
0 my sunday driver...
Last Post: Old Junk
0 MS rollers way too tight
0 What engine oil do you use?
0 Cam question
Last Post: Heff
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Last Post: oldboy
0 Bike Beast
0 Old new guy
Old 21st October 2019
Zari Zari is offline
Sportster/Buell Model: Xlh 1000
Sportster/Buell Year: 1982
Zari is an unknown quantity at this point
Wink air leak from intake
hello I have Sportster xlh model 1982 and one day I have problem with the float I take off the carburettor and fix the float problem, but after this i have poor acceleration have intake leak from the rubber manifold what can I do now please help.
doodah man's Avatar
I would start by putting on some new intake rubber bands. Then reseat the manifold to the heads. Is your carb supported with a brace to the engine?
What do you mean by "rubber manifold"?
Old 22nd October 2019
The manifold is usually steel or aluminum. It might help to say what carb you have; this might explain why there is a rubber manifold, or rubber connection between the carb and the manifold.
Think he means rubber bands. S&S carb?
http://xlforum.net/forums/showthread...40#post5778340
How do stink bugs live with themselves?
If it is a clamped rubber connection between the carb and manifold they often crack.
The carb MUST be supported, at the air filter backing plate is best.
Old 6th November 2019
Default air leak
yes support to the engine
rubbe bands between manifold and carb.
SS SUPER E
