Last Post: wrkdWS6
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 P0505 code on my '09 XL883C driving me insane!!
0 What weight oil?
Last Post: Serious Blac
Last Post: Brad
0 Not an ironhead, but....
Last Post: randy3934
Last Post: jcn59
0 Cable lengths
Last Post: xElvis
Last Post: Gulf Coaster
0 2011 1200C tuner?
Last Post: ktp1598
0 Timing
Last Post: Skeezix
0 Powerraythor conversion
Last Post: Traxx
Old 3 Weeks Ago
jsandidge jsandidge is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Suzuki GS850GL
Other Motorcycle Year: 1982
jsandidge is an unknown quantity at this point
Default Cracked motor mount
I just discovered a crack across my rear motor mount. I'm guessing the motor has to come out of the frame to replace it. What are my options?
Old 3 Weeks Ago
doodah man's Avatar
if it's on the right side edge between where the vertical and horizontal "screw plates" meet (?) then you are probably alright. or is it somewhere else? got a pic? does it vibrate your hands numb in short order?
Old 3 Weeks Ago
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Originally Posted by jsandidge View Post
I just discovered a crack across my rear motor mount... What are my options?
A pic would be really helpful. Hopefully one that's clear and in focus...
Old 3 Weeks Ago
It appears to be cracked just in front of the intersection of those “plates”. As for vibration, I have no frame of reference to compare to. This is my first Harley, and I’ve only had a couple test rides around the block. I do have the feeling it might be excessive.
Old 3 Weeks Ago
The crack is just to the left of the red line.
Old 3 Weeks Ago
doodah man's Avatar
yes, a bit excessive. many times they crack right on the edge and stop. if that was the case, i would've suggested ignoring it, but that's a pretty long crack. does it appear to go all the way across the top to the other side? type the part number 16203-67 into ebay and take your pick, but yes the case halves need to be split to replace the mount, unless you find a pingel. clean or replace that drive chain too!
Old 3 Weeks Ago
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Well I had to look it up, but The Pingle mount is available. $151.62 on Amazon.
From the photo, it might be possible to reinforce that area with a piece of angle iron with short spacers behind it and longer bolts.
Sleepy Labeef rides again!
Old 3 Weeks Ago
JonesL JonesL is offline
Sportster/Buell Year: 1971
C'mon now, you gotta look harder than that.
https://www.ebay.com/itm/Pingel-Rear...cAAOSwu6ldo-cf
"If a camel flies, no one will laugh if it doesn't get very far".
Old 3 Weeks Ago
doodah man's Avatar
One must be extremely careful with longer bolts extending into the trans cavity. On an ironhead, those holes go all the way through. Bolts and gears don’t mingle nicely!!
Old 3 Weeks Ago
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
From the pic, that looks like the shorter type mount. If I’m not mistaken, on a later Ironhead, it should just be the 2 upper bolts and the 3 stud nuts and it should slide right out without having to split cases. That’s with the motor out of the frame.
After you’ve replaced it, look at this thread to see how to set your motor cradled right in the frame.
http://xlforum.net/forums/showthread...1659782&page=3
