Last Post: fafcpa
0 my sunday driver...
Last Post: Old Junk
0 MS rollers way too tight
0 What engine oil do you use?
0 Cam question
Last Post: Heff
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Last Post: dodgetrucken
0 Bike Beast
0 Old new guy
Old 28th October 2019
There are 3 studs you will have to pull out of the cases to remove the mount. The mount will not usually slide off the studs.
Also search for my post regarding the tightening sequence for the motor mounts to remove the stress from the rear mount.
Top mount shimming and tightening last
jsandidge's Avatar
jsandidge jsandidge is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Suzuki GS850GL
Other Motorcycle Year: 1982
jsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to all
Originally Posted by Maxeffort View Post
From the photo, it might be possible to reinforce that area with a piece of angle iron with short spacers behind it and longer bolts.
I went to sleep with this idea last night. I'll make sure the rest of it is ok, but I might try this as a temporary fix.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
This (mock-up from scraps) is what I was visualizing. The spacers are for the counterbore in the mount holes and to clear the radius of the bracket. The longer bolts are to make up for the increased thickness of angle and spacer.
http://www.pingelonline.com/harley-d...sportsters.asp
mine has been cracked since 1975 after taking the front end off a 1972 chevy impala.
jsandidge's Avatar
Is yours cracked all the way across like mine? I guess it doesn't cause any problems for you since you've run it that long.
jsandidge's Avatar
Thanks. That is exactly what I was visualizing. I just cut my angle iron. I'll give it a try this weekend.
16203-67 There are 17 of them on eBay most less than $100 a few less than $50.
It's not worth it to patch it, the mounts don't break if the motor is installed correctly.
jsandidge's Avatar
I do plan on fixing it correctly, but I don't want to be splitting cases right now. I will go through the whole motor at some point, so it will get a new mount then.
ferretface's Avatar
I am confused...Why does the engine case need to be split to remove a motor mount??? I've looked at pics on eBay of them, they all look like bolt-ons...
Is that just for 1981 models??? Would I have to remove my engine and split the cases to remove my 1983 rear motor mount???
I originally read this thread to look at where the crack is and see if mine might also be cracked. It is 36 years old after all. But I'm not sure from the pic where the crack is - there is a curved dark line where there seems to be a boss, is that it???
I can't even see my rear mount, there is so much stuff covering it. Is that pic from underneath???
^^^^ it's between the 2 case halves. no room to get it out.
