Last Post: wrkdWS6
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 P0505 code on my '09 XL883C driving me insane!!
0 What weight oil?
Last Post: Serious Blac
Last Post: Brad
0 Not an ironhead, but....
Last Post: randy3934
Last Post: jcn59
0 Cable lengths
Last Post: xElvis
Last Post: Gulf Coaster
0 2011 1200C tuner?
Last Post: ktp1598
0 Timing
Last Post: Skeezix
0 Powerraythor conversion
Last Post: Traxx
Old 3 Weeks Ago
jsandidge jsandidge is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Suzuki GS850GL
Other Motorcycle Year: 1982
jsandidge is an unknown quantity at this point
Originally Posted by ferretface View Post
I can't even see my rear mount, there is so much stuff covering it. Is that pic from underneath???
I found this crack by accident. I pulled my starter to re-build the solenoid. The picture is of the top of the motor back at the down-tubes of the frame in front of the oil tank.
In the video linked here at about 49:00 there is a great view and explanation of where they crack and how to prevent it.
https://www.youtube.com/watch?v=2wX-S1WGTHI&t=2332s
Old 2 Weeks Ago
Originally Posted by jsandidge View Post
I do plan on fixing it correctly, but I don't want to be splitting cases right now. I will go through the whole motor at some point, so it will get a new mount then.
You don't have to split the cases to change the mount, just pull the three studs.
Ryder Rick "You want some aura, Dora? Right here on the flora?"
Old 2 Weeks Ago
That's good news. I had heard it was necessary.
Old 2 Weeks Ago
I'm confused now. I just watched another Tatro video showing the mount sliding over the 3 studs during re-assembly of a 77 ironhead. Are you saying I can replace the mount with the motor in the frame by removing the 3 studs?
Old 2 Weeks Ago
Ok, I got some expert advice. It looks like the motor does need to come out, but the cases don't need to be split. I will do that later this winter. I will put on the angle iron piece this weekend though and see if I can get in a couple of rides first.
Old 2 Weeks Ago
Regardless of the knowledge of the others who have responded here, I am not convinced about the use of a piece of Iron to hold the aluminum parts together. The iron [or steel] is way stronger that the aluminum. Any stress and the aluminum will break.
Perhaps I am wrong and someone can convince me.
Old 2 Weeks Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
That crack didnt happen yesterday. Fix it or fly it. A few more rides wont change a thing. Your wasting time figuring out band aids.
Old 2 Weeks Ago
+1
IronHeads with cracked rear engine mounts have been tearing up highways for decades. Nothing bad will happen. Fix it when you already have it apart for some other reason.
Old 2 Weeks Ago
You know, you guys make a good point about leaving it alone for now. At least I know what I need to do when it comes time. I will be pulling the motor later on anyway.
Old 2 Weeks Ago
rejeanprimeau's Avatar
Look more like a casting flaw than a crack, use ATF mix with diesel, paint the (crack) clean the area and shoot Soft & Dry anti prespirant and if it's crack it will show.
