Last Post: wrkdWS6
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 P0505 code on my '09 XL883C driving me insane!!
0 What weight oil?
Last Post: Serious Blac
Last Post: Brad
0 Not an ironhead, but....
Last Post: randy3934
Last Post: jcn59
0 Cable lengths
Last Post: xElvis
Last Post: Gulf Coaster
0 2011 1200C tuner?
Last Post: ktp1598
0 Timing
Last Post: Skeezix
0 Powerraythor conversion
Last Post: Traxx
RKN's Avatar
RKN RKN is online now
Sportster/Buell Model: 883 (90")
Sportster/Buell Model #2: 5" stroker in progress
Other Motorcycle Model: 900 CH engine in H frame
Other Motorcycle Year: 196?
RKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to all
Default Need help with identification of Linkert DC manifolds
I'm looking for a manifold for Linkert DC-10 carb. There're 2 types of 900 manifolds on ebay (pics from ebay listings):
Which type is correct for DC-10?
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Either of those should work.
They made steel manifolds from 57 to 71, alloy after that.
Both Big Twins and Sportsters used the same things.
The Big Twins ran the same carbs.
I believe the correct ones for Sportsters don't have the wide "ridge" inside where the incoming air/fuel hits the back wall but a sharper, pointed ridge. "Hard to describe but you'll know it when you see it".
http://xlforum.net/forums/showpost.p...98&postcount=6
I'm sure any could be made to work but according to this info the manifold used during the linkert years had a slightly closer bolt hole spacing. I have one that matches that dimension along with the throat diameter of 1.562". It has the sharp pointed ridge that Ferrous Head mentioned.
I believe the throat dimension for the 27021-71, 27021-71a, listed here may be an error. The throat size of the one from my 1974 measures 1.660" which is also the size of the bendix carb that came on it. Bolt hole spacing is 2.750. It has the wide ridge. not he sharp point where the runners intersect.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
So the top photo is the one with the sharp ridge?
Sleepy Labeef rides again!
For a Linkert you need the 27021-57.
In 71 they went to the Bendix on the Shovel which was probably why they changed the bolt holes.
RKN's Avatar
Thank you, gentlemen!
