Last Post: wrkdWS6
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 P0505 code on my '09 XL883C driving me insane!!
0 What weight oil?
Last Post: Serious Blac
Last Post: Brad
0 Not an ironhead, but....
Last Post: randy3934
Last Post: jcn59
0 Cable lengths
Last Post: xElvis
Last Post: Gulf Coaster
0 2011 1200C tuner?
Last Post: ktp1598
0 Timing
Last Post: Skeezix
0 Powerraythor conversion
Last Post: Traxx
Speedyone Speedyone is offline
Sportster/Buell Model: XLCR 1000
Speedyone is an unknown quantity at this point
Default xlcr elusive parts
hi, new to the forum and hope this is the right place to start.
finally restoring my CR and hoping i can get some advice with the last few parts. i can fabricate parts and with a load of luck someone out there might be able to supply some photos and measurements of the parts i have missing ??, rear turn signal brackets, fairing support brackets and rectifier bracket. heres hoping thanks
doodah man's Avatar
can't exactly help with your quest, but welcome to the forum from roanoke va!
sml1226 sml1226 is offline
http://www.imagenet.net/ironhead/parts.htm
No info on this site, but lots of stuff there. May be worth sifting through. That's assuming you're fabricating because you can't find things though.
Also:
https://www.budkepowersports.com/oem-parts
Goes back to at least a 77. Should at least be able to find part numbers to further the search if you do want to try tracking originals down.
Thanks for the welcome, hope I can also be be of help to others on their restorations
harley506d's Avatar
Sportster/Buell Model: 1200c
Welcome from France!
Good luck with finding the missing parts. Post pics when you can.(use imgbb.com)
Do you already know about this?...
http://www.xlcrclub.com/
Hi Mick , thanks for the info, yes i knew about the club and had already contacted them quite a while back, sadly the club and membership had been suspended due to operational help.
Coz's Avatar
Coz Coz is offline
Other Motorcycle Model: 1970 XLH, 2002 Ducati S4
Coz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant futureCoz has a brilliant future
I sold my XLCR about a month ago but it is still sitting in my garage. Despite paying for it Buddy hasn't come to get it yet. I can take photos of the bits on the bike. Let me know what you need.
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Forgive my terminology ignorance, but isn’t the gear selecting portion of the XLCR transmission unique in that the shift pattern is reversed? If so, how rare is this part of the transmission? I’d like a reverse pattern on my ‘81 IH racebike but the linkage to do this with the way I’ve fabricated my rearsets is tricky and you can’t simply turn the shift lever around like on other bikes.
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
Scott...
Just undo the selector disc from the pawl carrier, grind the weld, pull disc off shaft off, turn disc over and re-weld, so not rocket science!!!
Patrick
Flat Head Forever
