Last Post: wrkdWS6
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 P0505 code on my '09 XL883C driving me insane!!
0 What weight oil?
Last Post: Serious Blac
Last Post: Brad
0 Not an ironhead, but....
Last Post: randy3934
Last Post: jcn59
0 Cable lengths
Last Post: xElvis
Last Post: Gulf Coaster
0 2011 1200C tuner?
Last Post: ktp1598
0 Timing
Last Post: Skeezix
0 Powerraythor conversion
Last Post: Traxx
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Originally Posted by rejeanprimeau View Post
Take a mirror and look at your lifter roller, you need about 0.05 inches shoulder for the roller to sit on the cam, the rest can go in the scrap bin. I use a lathe to do it.
You turned the cam on the lathe, or the roller? If it was the lobe, did the machining affect the surface hardness (or am I thinking too much). A little off the lobe would mean less off the case.
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I had to take some off the lobes. That was 5yrs ago. Used a bench grinder.
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant future
I clearanced the cases with a dremel with the motor assembled and in the frame. Spent more time with the masking tape than it took to do the grinding in the cases. Tried the dremel on the cam lobes, but that would have taken all day. Bench grinder was the way to go on the cam lobes.
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
The side of the cam lobe. If you grind, tape up the lobe where the roller rides and tape it very well. One slip up...
Before you grind any lobe, I’d mock it up, cam and lifter, rotate it marked up with some Prussian blue paste or gear marking compound, etc... and be certain where the lifter roller rides.
As long as you go slow with grinding and keep it cool, it should be fine. Cutting with a lathe won’t change anything... unless the operator is an animal.
Sleepy Labeef rides again!
rejeanprimeau's Avatar
You machine the cam. Hold the cam on the shoulders gear side. Remove a bit of the corner or the full face of the lobe, your choice. You can also clearance with a grinders, just make sure you use a fine wheel and keep it cool.
cxf's Avatar
cxf cxf is offline
Sportster/Buell Year: 1985
Other Motorcycle Model: cb450
Other Motorcycle Year: 1974
cxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the roughcxf is a jewel in the rough
Looks like you have found your answer and you don't need me to search for my buried Qs?
Correct, sir. Thank you very much for the offer, though.
