0 mainshaft rollers size
Last Post: dodgetrucken
0 my sunday driver...
Last Post: Old Junk
0 MS rollers way too tight
0 What engine oil do you use?
0 Cam question
Last Post: Heff
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
0 Bike Beast
Old 9th November 2019
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
Default Cam spec chart
I came across this "H-D Master Cam Specs" chart. Not just factory but it looks like aftermarket too.
Lift, duration, degrees at opening/closing, overlap, the works. If this isn't already listed somewhere in the forum it might be handy to have.
If you hear hoofbeats-- think horses, not zebras.
ferretface's Avatar
ferretface ferretface is online now
All I get is an unreadable text. What program is everybody using to open this???
1skullster1's Avatar
1skullster1 1skullster1 is online now
Sportster/Buell Model: XLH, XLCH
Sportster/Buell Year: 66,
Sportster/Buell Year #2: 68
Other Motorcycle Model: XLH
Other Motorcycle Year: 75
1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute1skullster1 has a reputation beyond repute
Try this link:
http://www.nightrider.com/biketech/HDMasterCamSpecs.pdf
Old 10th November 2019
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
https://documentcloud.adobe.com/link...7-60390c178b77
Old 11th November 2019
Thanks skullster.
That's the chart I was trying to post but all that comes across is the text version.
