0 Hello from Waipu, New Zealand
0 New member from Santa Clarita, CA
Last Post: Nayra
0 What oil temp do you run
Last Post: oupa
0 Frontbrake upgrade - simple and cheap - how to will follow if there's any interest
Last Post: Yakcm2
0 In PA Or Nearby
0 A thunderstorm -weather that is
0 stock modded exhaust vs short shot
Last Post: Bruce
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
Last Post: Darkseacret
Last Post: Beelzeboss
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 Fork Spring Rate measurments, sag and more
Last Post: pdavis5160
5 my 3D printed turn signals.. what would you print?
0 Frame-mount Danmoto baffle removal?
Last Post: Curbside
Last Post: davixlrtt
0 compression problems
Last Post: BWP 5p
0 02 sensor query
0 Chrome or Dark Custom
Last Post: frogg_nutts
Old 27th June 2018
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Have you got the old parts? Check the rotor thickness of old parts to new ones.
Old 27th June 2018
Peteroo Peteroo is offline
Sportster/Buell Year: 1979
Peteroo is an unknown quantity at this point
the thin gerotor is .006 above the upper houseing lip which is within spec, couldnt find another spec to measure. it all seems together correctly, i will quadruple check it tonight
Old 28th June 2018
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Yeah, that sounds like it is good. Try leaving out those feed gerotors and see if they are causing the bind. If it spins free without them you know your problem.
