0 Sportster Fork Upgrade
Last Post: PetesPonies
0 1979 Ironhead Starter Washer, Bushing
Last Post: Tipofthelake
0 Yearly Allotment of Miles
Last Post: a-sad-anorak
0 Highway cruise speed
Last Post: rich56
0 Why such heavy oil in Sportster?
Last Post: rich56
0 Be Careful Out There!
Last Post: RDHenley
Last Post: 1skullster1
0 The last of a dying breed...
Last Post: Bryan1976
Last Post: RDHenley
Last Post: smilinbrad
0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
Last Post: kodylk08
0 Parts
0 Tranny oil
0 Chinese S&S carbs
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
Last Post: Nitro57xl
0 XR mutt race bike progress
Last Post: bklyngeezer
Last Post: Blackesthart
0 Carb starting issue.
0 WTB NOKK needle...
0 Wont Fire up!
Last Post: Mission1
Last Post: FiftySixer
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 27th May 2020
No I don't.
Mine is a 98 model.
Old 28th May 2020
With the proper wiring diagram, you can see what wire colors run to each device.
Info off the top of my head (may be incomplete):
Here's a thread on eliminating the Turn Signal Module:
http://xlforum.net/forums/showthread.php?t=847440
http://xlforum.net/forums/showthread.php?t=573200
The ICM, TSM & Speedo all communicate thru the Serial Data Link - You may encounter error codes... Does your bike have the security function?
You need the Crank Position Sensor & the MAP Sensor for the engine plus the Vehicle Speed Sensor for the Speedo.
The GREY wire is power from the Ignition Fuse.
The ORANGE wire is power from the Instruments Fuse.
The ORANGE/White wire is power from the Accessory Fuse.
The BLUE wire is power from the Lights Fuse.
The BROWN/Grey wire is power from the Battery Fuse.
The WHITE/Violet wire is the Left TS wire from the Handlebars.
The VIOLET wire is the Left TS wire to the lights (front & rear).
The WHITE/Brown wire is the Right TS wire from the Handlebars.
The BROWN wire is the Right TS wire to the lights (front & rear).
This may also be helpful:
http://sportsterpedia.com/doku.php/techtalk:ref:elec08
Old 29th May 2020
wannabehero wannabehero is offline
Sportster/Buell Model: 883L
wannabehero is an unknown quantity at this point
Ive secured wiring diagrams for my year. I dont believe i have any security system. Is there any sure way to tell?
Old 29th May 2020
RDHenley's Avatar
RDHenley RDHenley is offline
Sportster/Buell Model: XL883C
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Street XG500
RDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond repute
The Factory Service Manual has pretty good diagrams, though for my 02 and 05 they are not in color, but are on fold out pages so they aren't too hard to read. IXL2Relax is correct on needing the Crank Position Sensor & the MAP Sensor, but there may be others necessary also. I'd sure want to do some reading in the manual to figure out where all the sensors are and what each does before trying to decide what's necessary and what isn't.
Old 29th May 2020
The part number displayed during diagnostics should reflect either TSM or TSSM - and the unit itself, located under the battery tray, can be examined.
Old 2nd June 2020
Just a TSS on this bike
JohnAkaB JohnAkaB is offline
JohnAkaB is an unknown quantity at this point
If you don't want to mess with any wiring. Lowbrows offer the minimal wire harness kit for $200ish
https://www.lowbrowcustoms.com/produ...ortster-models
