Keep & Kill
1 Week Ago
Posts: 25 Sportster/Buell Model: XLCH Sportster/Buell Year: 1969 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1971 Other Motorcycle Model: XLCR Tribute Other Motorcycle Year: 1980
What grease to use for starter needle bearing?
I'm putting together some starter motor/solenoid assemblies and have a question about lubricants.
What's the best kind of lube to use on the motor housing needle bearing (part number 9062)? Do I just use the same multi-use high temp bearing grease I use on my wheel bearings? Do I use assembly lube?
The FSM didn't seem to specify. I don't want to do any damage...
1 Week Ago
Posts: 105 Sportster/Buell Model: sportster xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 73 Other Motorcycle Model: sportster Other Motorcycle Year: 2003
needle bearing grease
I prefer a light coat of assembly lube.Oil from the primary will slosh all over once your running lubricating starter needle bearings and also the counter shaft needle bearings.Hi temp grease is not necessary but a light coat of say tacky red will also work.
1 Week Ago
Posts: 875 Sportster/Buell Model: XLCH Sportster/Buell Year: 2003 Sportster/Buell Model #2: XL Sportster/Buell Year #2: 1981 Other Motorcycle Model: FXDC Other Motorcycle Year: 2013
I would use assy lube as it heats up and dissipates
Steve
'03 1250 stage two thunderstorm heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
1 Week Ago
Much thanks for the recommendation. While I love old bikes I'm not by any measure a mechanic.
