0 Tappet blocks and tappets
Last Post: Scott
0 Coil readings
Last Post: Billy1200
0 Hammer 1250
0 3/4” Axle Drum Brake ??
Last Post: thefrenchowl
0 primary cover
Last Post: smoggy
5 Eye Protection When Riding?
0 Inherited Ironhead
0 New Guy with Experienced Bike
8 Inexplicable miss
0 normal shifter shaft wobble
0 New guy from IL
0 Front Brake Upgrade
0 1992 XL ignition explained
14 I just kind of stumbled in here... like 100 times.
0 Ignition advice
0 Chinese S&S carbs
0 41mm V-Twin Narrow-glide conversion for XL
0 Bandanas
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
0 Proven external Fuel pump and regulator
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Top end reassembly...what goes where!?!?!
0 UltraCool oil cooler safety concern
warpusher, Terp84Alum, FiremistSLK (74), moony956 (72), E.H-57 (63), bplinson (56), fbroos73 (47), prefect (40), bamf_shadow (38), jakebuganski (38), Arwalkz007 (37), Fraser19 (31)
39mm, dual discs, front end, spacing, upgrade
Old 6th April 2020
shrimp shrimp is offline
Sportster/Buell Model: XL883
shrimp is an unknown quantity at this point
Default Dual Disc Conversion - Slider Clearance
I've got a 98 883, it's been neglected for a while now. I've been sitting on a pair of 99- dual disc 39mm lowers, and a pair of dual disc calipers, floating rotors and matching master cylinder - all parts I've gotten at swaps. Haven't been riding the sportster much, but decided with the quarantine that now is the time to get the hog back on the road.
Took off my old lowers and loosely assembled the new lowers (without putting in fluid/springs or bolting in the dampeners) I decided to do a test fit with the brakes mounted and put the rotors on the wheel and see how everything fits.
I noticed two things I have questions about.
First, spacing against the right slider and the rotor bolts is very tight compared to the left side. I'm using the factory wheel spacers. Is this normal? The wheel spins fine as it is.
I've tried getting inline pictures but not having luck. Here's a link to the current spacing
https://imgur.com/a/vqnvn5R
Second question: My factory axle doesn't fit into the new left side lower. The new lowers I.D. (where the axle meets) is about 0.15mm smaller than my factory lower (I've ordered proper dial calipers and telescoping gauges so I can get a more accurate measurement)
Thinking about putting the axle on a lathe and using emery paper to get it to fit - unless this is a red flag. Is it normal for tolerances to be this tight? My second thought is to use a master cylinder honing tool and try and gain that space on the fork lower, instead of taking material off the axle.
Thanks
Old 7th April 2020
I've continued to try and figure this out. My FSM does NOT have any details on dual disc brakes. I eventually found this post http://xlforum.net/forums/showpost.php?p=3022954&postcount=9
It seems that there are different instructions for dual discs, including mention of a 7/16th drill bit to ensure brake rotor alignment.
Anyone have a copy of a manual that has these instructions and could snap a pic?
Old 8th April 2020
That drill bit slips into the hole near the end of the axle, it butts up against the flat on the bottom of the slider to give you proper clearancing.
