0 Adjusting Drive Belt While On A Lift
0 N65C or N65A
Last Post: lespaul6
0 Tappet blocks and tappets
Last Post: Scott
Last Post: Scott
0 Turbo Iron 883
Last Post: Ghostdog
0 Need some guidance on installing a traxxion dynamics suspension on my front forks
Last Post: Bryan1976
0 "S" model specific Q&A
Last Post: Buellbomb
0 Chinese S&S carbs
12 Crankcase breathing?
Last Post: DJCBlue
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sportster Fork Upgrade
Last Post: Redbeard2
0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 Ground Up Beginner Build
Last Post: Paul.W
Last Post: PetesPonies
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
0 New Guy with Experienced Bike
Last Post: Bikeaholic
0 Info needed on mini sumps.
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 5th April 2020
The one I just took apart had a plastic pin pushed into the hole in the wheel to drive the tab on the speedo drive. I haven't looked into it further.
The Pie Slice Caliper?
I don't like flipping the rotor to the right side as the caliper mount is not designed to take pushing forces and may try to taco the mount.
ALL of HD's floating calipers rattle, ALL OF THEM rattle and wear out the mounts so they rattle more.
If you want to get rid of the rattle install a Ninja (or equivalent) Caliper, I am using Tokico calipers on my Hooligan bike.
