0 Reflectors...Yeah, or Neh
Last Post: Mike1nw
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: thefrenchowl
0 Emission hose loose
Last Post: Mike1nw
0 Can’t go over 70mph
0 fork oil
Last Post: Mike1nw
0 fuse block
Last Post: Mike1nw
0 Wet Sumping (No oil returning)
Last Post: FalcoFlash
0 Resto-Repair 84 ironhead
0 Air filter Q
Last Post: Billy1200
Last Post: maltesefalcon
Last Post: Akdawg
0 ultima install without VOES
Last Post: supermotolew
0 TC88A Maps for 883 to 1275 Basic Converstion
0 Chinese S&S carbs
Last Post: T. Clark
0 Recent 1275 Dyno Tune
0 Hammer 560 VS 570 Felt differences?
0 2006 XL1200 OEM Battery Dimensions
merc, schvamf (48), MikeLightnin, o2man98 (40), Toadz (32), WingNut15B (32)
Old 7th April 2020
volvocanadian volvocanadian is offline
Sportster/Buell Year: 1966
Other Motorcycle Model: Aermacchi Sprint H
volvocanadian is an unknown quantity at this point
Default oil drive and gear timing
okay, it has been 7 years since I did this last and I am not sure I did it quite correctly
followed the factory manual about inserting the oil pump and rotated the flywheel to the single line timing mark in the center of the timing window on left side of the motor
turned the oil gear so the hole is in the window of the shaft and slid the oil pump drive gear on - there looks to be a timing mark on one of the teeth like on the cam gears but it did not line up with any of them - weird?
I then put the pinion gear on, it also had a timing mark on it and it did line up with the cam gear marks - all good?
the oil pump and pinion gears both have one longer recess than the other recesses for it to slide onto the pinion shaft in one way only, so the oil pump gear timing mark means nothing? there is no way for it to be the same spot as the pinion gear mark that slides directly over it...
next question - when the single line timing mark is in the window - should that put the front piston at the very top of the cylinder? TDC? the manual doesnt say whether the piston should be at the very top or not, it just says to get the line in the center of the window
my front piston sits about 3/4" below the upper lip of the cylinder but the rear pistons sits at the very top - or do I need to release the cam gears from the oil pump drive gear and rotate the flywheel again to the single line so the front cylinder is at the very top? does it go to the top if I do that? is this now 180 degrees off?
I dont want to go any further (actually I do but since Id ont have acompensating sprocket extension I cannot) until this is figured out
thanks
Robert
Old 7th April 2020
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
the vert line should be the advance timing mark so the piston would not be at TDC
strange because you install the oil pump drive gear, then the pinion and then the cams?
Old 7th April 2020
click to enlarge
Old 7th April 2020
doodah man's Avatar
I believe any oil pump drive gear mark is coincidental? If the oil pump timing mark is in the window with the pump fully seated and the ignition advance Mark is centered then it sounds like you did it right to me.
Nine mile skid on a ten mile ride, hot as a pistol but cool inside.
Old 7th April 2020
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
my front piston sits about 3/4" below the upper lip of the cylinder but the rear pistons sits at the very top.....
On a 900 motor, with stock flywheels:
  • the "|" vertical bar in window = 45° BTDC on the FRONT cyl
  • and, it just so happens, the "|" vertical bar in window also = TDC on the REAR cyl
The underlying premise is..... anywhere in the flywheel rotation, the REAR cyl always runs 45° ahead of the FRONT cyl.
Old 7th April 2020
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
The breather alignment to the timing mark is correct.
The cams do NOT line up at the same time.
