Last Post: Abo
0 900cc Pistons
Last Post: mickey t
Last Post: tattooglisha
0 Le Pera seats in Australia
Last Post: BSA Bob
Last Post: RDHenley
5 Terminology Sticky?
Last Post: commando57
Last Post: ronccc
Last Post: RDHenley
0 No oil flow
Last Post: MkC
Last Post: SwissXL
2 Your daily tunes...
Last Post: RDHenley
Last Post: batchman
Last Post: SwissXL
0 Highway cruise speed
Last Post: SwissXL
Last Post: Kenb
0 Getting Hammered
Last Post: Bryan83taco
0 Willi is back!!!!
Last Post: Oldmxdog61u
0 Problem on a trip
Last Post: 1968xlch900
0 2004 ICM
Last Post: mrmom9r
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: 1Scooter
Old 9th April 2020
Sportster/Buell Year: '59
Other Motorcycle Model: 2006 XL1299R
PetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant future
Default Coil relocation '06 R
Used a horn/choke bracket from a C. I used on one my '04 R because I wanted the horn mounted there. I used one on this '06 R because it has a choke provision and a perfect spot to mount the coil bracket I made.
Pete's Ponies Mustang RUSToration & Performance
Old 10th April 2020
Nicely done, thank you for posting it!
Old 10th April 2020
Thanks. Engine looks better in person . . .camera makes it look bad
