Last Post: Abo
0 900cc Pistons
Last Post: mickey t
Last Post: tattooglisha
0 Le Pera seats in Australia
Last Post: BSA Bob
Last Post: RDHenley
5 Terminology Sticky?
Last Post: commando57
Last Post: RDHenley
0 No oil flow
Last Post: MkC
Last Post: SwissXL
2 Your daily tunes...
Last Post: RDHenley
Last Post: batchman
Last Post: SwissXL
0 Highway cruise speed
Last Post: SwissXL
Last Post: Kenb
0 Getting Hammered
Last Post: Bryan83taco
0 Willi is back!!!!
Last Post: Oldmxdog61u
0 Problem on a trip
Last Post: 1968xlch900
0 2004 ICM
Last Post: mrmom9r
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: 1Scooter
fuses, ironhead, solenoid, starter bendix
Old 10th April 2020
MotoSteward MotoSteward is offline
Sportster/Buell Year: 76
MotoSteward is an unknown quantity at this point
Originally Posted by 72 Ironhead XLH View Post
The standard 3 post is B battery, I ignition, L lights and standard wiring is resetting CB`s not fuses
No CB’s on this rig. All in line fuses.
The three posts I have on the ignition are B, S, I
Old 10th April 2020
Originally Posted by brianbbs67 View Post
I agree YK. 30 amps runs my dryer or heat pump. OP, you have a dead short in that circuit.
That’s my fear. My circuits worked fine before I replaced my ground wire. I could turn on power, switch from hi— low and even engage the starter. Now, the solenoid and starter were not turning the engine ( that’s a different problem) so I thought it could be the solenoid. Measured amps on the solenoid and it was even pulling one amp. Called the shop and asked for a new solenoid. Meanwhile, I asked if he could make me a New ground wire cause the old one looked crusty. Got the new ground wire.. I put a brand new ground wire from the frame to the NEGETIVE post on the batt. Wanted to test it before installing a new solenoid ( to be sure). Then voila. I start blowing fuses when switching from high to low. If I don’t touch the hi low switch I can engage the starter and solenoid ( still doesn’t turn engine) but the fuses don’t blow. Soon as it’s switched to hi. All three go poof.
Old 10th April 2020
Yellowstone Kelly's Avatar
Yellowstone Kelly Yellowstone Kelly is offline
Ironhead Rider
Sportster/Buell Model: XLH 1000, Stock
Sportster/Buell Year: 1982
Sportster/Buell Model #2: XLH 900 Hardtail Chop
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant future
Default ome
Without being there to see how things are connected, it's hard to help.
I'm not trying to insult you, but when you put the starter and solenoid unit back on the bike, you connected the battery positive cable to the long, large solenoid stud, right? And the short, large solenoid stud is connected to the starter motor post? I don't know what would happen if these are reversed.
Somehow, when you're switching the lights to high beam, you're grounding the circuits well enough to blow the fuses, and that's a lot of current. I don't see how just replacing the cable from the battery negative cable to the frame could cause this. And I don't understand how the high/low light switch could be connected in any way to the starter relay and solenoid circuits.
http://xlforum.net/forums/signaturepics/sigpic72446_4.gif
Old 12th April 2020
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant future
Originally Posted by rokytnji View Post
Simpler way. Bigger fuse and watch what melts.
lol. But this could be a good way to fry the whole wiring harness too.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
Old 12th April 2020
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Year: 1974
" Originally Posted by rokytnji View Post
Simpler way. Bigger fuse and watch what melts"
Don't let too much smoke out, I have seen what happens and it ain't pretty!
