Last Post: tattooglisha
0 Le Pera seats in Australia
Last Post: BSA Bob
Last Post: RDHenley
5 Terminology Sticky?
Last Post: commando57
Last Post: ronccc
Last Post: RDHenley
0 No oil flow
Last Post: MkC
Last Post: SwissXL
2 Your daily tunes...
Last Post: RDHenley
Last Post: batchman
Last Post: SwissXL
0 Highway cruise speed
Last Post: SwissXL
Last Post: Kenb
0 Getting Hammered
Last Post: Bryan83taco
0 Willi is back!!!!
Last Post: Oldmxdog61u
0 Problem on a trip
Last Post: 1968xlch900
0 2004 ICM
Last Post: mrmom9r
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: 1Scooter
0 Front brake hose
Last Post: flthd31
0 Exhaust pipes
Last Post: Joe_jeep
Old 6th April 2020
Joe_jeep's Avatar
Joe_jeep Joe_jeep is offline
Joe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond repute
Default xied or x14ied?
i was about to do a stage one on my 2010 xl1200 low.
im out of work for a while now, that aint happening.
while im out of work, im installing my mufflers, and saddle bags.
i might add a cheap air cleaner into the mix, but i have not bought that yet.
all the other parts i have already, thats why im putting them on.
im considering an xied or x14ied as a stop gap till i can afford a pv tuner.
any input as to what is better between those two?
all opinions welcome.
thx
Old 6th April 2020
Madjak Madjak is offline
Madjak is an unknown quantity at this point
I went with the vied it was adjustable works great with my vance n hines pipes n non stock air cleaner
Old 6th April 2020
Joe_jeep's Avatar
i will look into that one too.
thx
Old 6th April 2020
11alan111 11alan111 is offline
Sportster/Buell Model: 883r
11alan111 is an unknown quantity at this point
the person who sold me parts said do not bother with an XIED,cause it tells lies to your ecu
Old 7th April 2020
BKB's Avatar
BKB BKB is offline
I had the XIEDs on mine for about 80,000 miles. I put them on when the bike was new in '09, along with an Arlen Ness Big Sucker air cleaner & stock mufflers with home made, freer flowing baffles. It ran good, got 45 mpg, topped out at about 115 mph. But it had a randomly recurring high idle problem. Finally got tired of messing with it, took off the XIEDs & nothing changed except the high idle has not come back in the last 20,000 miles since I removed them. The plugs still read good, light tan, & there's no popping on deceleration. I'd try it with out them & if you don't get an overtly lean condition, don't spend the money until you can get a proper tuner.
Old 7th April 2020
Joe_jeep's Avatar
thx for the input everyone!
Old 7th April 2020
Bluto Bluto is offline
That is true AND that is the point...the XIED uses a simple resistive voltage divider to alter the oxygen sensor voltage so the ECU thinks the bike is running leaner than it is and the ECU then richens the AF ratio a bit. A tuner is definitely a better solution but XIED's do work OK for Stage 1 (freer flowing AC and exhaust)
Old 9th April 2020
Joe_jeep's Avatar
i just purchased a set of used xieds on here.
should be here in 3 or 4 days i assume.
if i like how they work, i will run them till i can get a tuner.
when i get a tuner, they will go on my sisters stock sporty.
Joe_jeep's Avatar
they showed up, looked like new.
i installed them, was quick and easy.
i removed the battery for a couple days.
installed the xieds, and installed a new battery.
runs well after the install. no check engine light.
no decel popping, runs smooth after the mufflers and ac install.
so far, so good.
i wish i could find more info about them such as af tables and dyno results.
