Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 > XR-1200
XR-1200 This area is strictly for XR-1200 discussion only
0 80 xl1000 oil not circulating?
Last Post: smilinbrad
0 Wont Fire up!
Last Post: Mission1
0 Coil polarity
0 XR mutt race bike progress
0 show me your sporty next to an old or rural post office
Last Post: Hellbent_4
0 clutch issue
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
0 Warm/hot kickstart
0 Rubber mount gas tank part
Last Post: awright2009
0 Top end failure
0 Ebay ****evil knievel bike****
Last Post: gusm2
0 "S" model specific Q&A
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
  #331
Old 31st May 2020
Davo_137's Avatar
Davo_137 Davo_137 is online now
Sounding really good, nice when a plan comes together, happy for you!
Thanks Paul.
Bike feels a lot better but it’s not quite there yet. But that’s just me not really knowing what I’m doing haha. I think I have the compression right now going by the cable ties I’m using for markers. But the front still feels a bit harsh and the back feels a little bouncy at speed. I’m hoping that’s the rebound, so that’s what I’m playing with next haha... I should probably read some more on subject.
You can just make out the black cable tie around the rod.
Old 1st June 2020
Yep, lots of adjustments to play with, nice way to bond with your ride!
Old 1st June 2020
Davo_137's Avatar
More “bonding” today, not out on the highway though, in the shed. Replaced the front brake pads. The honda shop had some aftermarket pads but they were way too expensive. The Harley shop had genuine pads for the same price as the Honda shop pads but the genuine set is a kit that comes with new pins and spring plate so I grabbed them. My pins are showing a little bit of wear and would probably be ok for awhile yet but I like the idea of everything knew. And why not if the kits cost the same as a set of aftermarket pads.
Old v new
A little bit left on the old pads but not much.
All done.
Recently I have noticed the fuel consumption had jumped up abit. I watch it closely with the powervision gauges. The intake side didn’t seem to have any leaks when I checked it last week. The headers had a lot of browning near the flanges so I got some new screamineagle exhaust gaskets and fitted them today aswell. The exhaust flange nuts didn’t feel very tight when I took them off, and the gaskets weren’t looking very good either. I think I must of used the stock gaskets last time, they were all squashed and protruding into the exhaust port. I got the front gasket out in one piece but destroyed the rear one getting it out.
Front gasket.
New screamineagle gaskets installed.
Hopefully this has solved the fuel consumption mystery.
Old 1st June 2020
RDHenley's Avatar
RDHenley RDHenley is offline
Sportster/Buell Model: XL883C
Sportster/Buell Model #2: XL883C
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Street XG500
Other Motorcycle Year: 2015
RDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond repute
From my own experience, you''re not going to get much past that before you push the pedal and find that nothing happens.
*Silver '05 883C Miss Molly* *Purple '02 883C Robin Marie*
Old 1st June 2020
“Rooman”, he, he, you might find that going to the copper exhaust gaskets may be a better option in the future. They are a round profile and slip into place much easier without squishing out into the exhaust flow at the head. I have developed a routine of snugging the header nuts every few thousand miles. Really like the copper, F.W.I.W.
If they seem a bit snug some time in the freezer helps them slide in easier, works with the woven style as well.
If they are a bit snug, don’t force them simply put them into the freezer for some shrinkage, works well on the woven style as well.
Old 1st June 2020
Davo_137's Avatar
I bet that got the adrenaline pumping haha
Old 1st June 2020
Davo_137's Avatar
“Roman”, he, he, you might find that going to the copper exhaust gaskets may be a better option in the future. They are a round profile and slip into place much easier without squishing out into the exhaust flow at the head. I have developed a routine of snugging the header nuts every few thousand miles. Really like the copper, F.W.I.W.
Ok. I’ve never seen them before. Who makes them?
Old 1st June 2020
wedge's Avatar
wedge wedge is online now
Money to burn. Heck, I would run those pads right down into the backing plate.
Old 1st June 2020
Davo_137's Avatar
Haha when you hear the sound of metal on metal it’s time to start thinking about new pads?
Old 1st June 2020
RDHenley's Avatar
Better stopping distance if there isn't a bunch of pad material in the way, right?
