Last Post: james beam
Last Post: Tipofthelake
Last Post: keithnh
0 Valve Lengths?
Last Post: motorhedmike
0 Chinese S&S carbs
Last Post: 11B40
Last Post: JonesL
0 73 XLH Total Power Loss
Last Post: sleighcrane
0 Cleaning carbon build-up
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
0 HF bike lift
Last Post: jharback
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
Old 24th October 2019
brucstoudt brucstoudt is online now
Default '03 883 custom only idles with the choke on
the '03 Sportster I inherited from my dad will only idle with the choke on.dies when you give it throttle,dies when you turn off the enrichener.sounds like a clogged jet to me.has the stock keihin cv carb -96a.has anyone else experienced this?
sportsterdoc's Avatar
Clogged idle jet is first guess.
Could also be intake leak:
a. Intake rubber cracked or not seated
b. Vacuum hose to VOES or vacuum petcock off or cracked
thanks sportsterdoc.i haven't been able to ride this yet since I trailered it home.
If it sat for awhile, I'd go over the full checklist in the SP to make sure everything is good and reliable:
Sportsterpedia - Getting Ready to Tune Your CV40 Carb
It's always cool to inherit somethng meaningful to your Dad...
Sportster/Buell Year: 1991
It's super easy to rebuild the carb and change out all the manifold gaskets. It'll probably purr like a kitten after that.
John
Old 25th October 2019
thanks for the SP link IXL.i'm not sure when I can get to this.have some major rust repairs planned for my 17 yr.old pickup truck before winter.this is something I would normally do on vacation time in the summer but spent my entire vacation getting the family farm ready to be sold.i have a serious backlog.3 projects planned for the ironhead.
If the bike has been sitting, it won't get any worse waiting to be maintenanced - Just take your time and check it all over so you can enjoy the ride without worrying about various stuff breaking down...
Once you give it a good going over, with replacement of the seals and any cracked hoses, you'll find these models are quite reliable...
The battery & system ground wires are added onto the upper rear motor mount bolts - You'll want to be sure to check those wires for condition & clean & tighten them...
The one weak point the '98-'03 models have is the nosecone igniton (HD very quickly stopped making replacements) - Not everyone had problems, but it is something to keep an eye on - the Ultima aftermarket version has gotten a fair bit of usage around here and is considered the go-to replacement...
Old 29th October 2019
night-train night-train is offline
Sportster/Buell Model: modded XL883/1250
Sportster/Buell Year: 97
Other Motorcycle Model: FLHTCU
Other Motorcycle Year: 2008
night-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to behold
If it's going to sit awhile, run a little seafoam thru the system. Let it start doing the work for you.
Drain the gas tank down to a gallon or less, add the seafoam, and run the bike for a few minutes. Shet it down, and get back to it whenever.
Old 21st November 2019
the weather was pretty decent when I got home from work today so I thought I would drain the old gas from the tank and carb.no luck there.i removed the fuel line from the carb turned the petcock on no fuel from hose in reserve or on position.fsm says must have vacuum to operate.while removing the fuel inlet hose the carb was moving up and down and eventually came off of intake manifold.i thought I found my problem with the way it runs but fsm says that's how it's attached.with no clamp.so not much accomplished today.besides reading the fsm.
Racepres's Avatar
Racepres Racepres is offline
Racepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to behold
Yer gonna need to support that carb... falling off is Not normal...
