0 Yearly Allotment of Miles
Last Post: 5mel42
0 Cam needle bearings correct install
Last Post: mrmom9r
0 95 tank on a 94
Last Post: Nilzar
0 73 XL 1000 Sportster - SOLENOID BYPASS
0 Headwork
0 WTB NOKK needle...
Last Post: lespaul6
Last Post: FiftySixer
0 theNeckerCube's Problems (Exhaust, Carb, … ?)
0 80 xl1000 oil not circulating?
Last Post: pucketprutectah
0 Can’t go over 70mph
0 Oh these college kids
0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
0 ultima install without VOES
Last Post: supermotolew
12 Crankcase breathing?
0 Tranny oil
0 Parts
Last Post: XL Ed
0 Mikuni Knock Off "REVEALED" !!!
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 4th April 2020
ferretface's Avatar
Originally Posted by Robyart View Post
Have seen adverts for 14 inch shocks and wonder if those are the correct size and if the bike was lowered. Don’t know how to I.D. Front forks either?
My original rear shocks on my '83 XLH are 12 1/2" eye-to-eye with the bike free-standing. My front forks, presumed original, are 32" from top of fork nut to c/l of front axle. There's a pic in my profile someplace showing how it looks on its sidestand.
Old 4th April 2020
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud of
According to the manual, your 84 should have 6.75" ground clearance.
Is the seat thinner than what you had on the 70?
Old 4th April 2020
Robyart Robyart is offline
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 84
Robyart is an unknown quantity at this point
Default Ground clearance
Thanks, for input, now have to measure and compare; because of virus emergency it’s not easy to get to my workshop. Were you referring to PARTS manual? Service manual doesn’t seem to cover this. As far as seat height, my ‘70 had an aluminum seat that I hammered from a piece of scrap. it was bolted right to the frame, maybe 1/4 inch thick. Everybody please stay safe and healthy, R.
Old 4th April 2020
BigMek's Avatar
Factory service manual has ground clearance, dry weight, etc. at the beginning of the Chassis section.
If the bike feels too low you could get a thicker seat. Honestly my 82 feels on the edge of too tall for me, but I'm average height and the seat is fairly thick.
Never had any ground clearance problems, but I don't hop curbs or anything so I've never worried about it.
Old 4th April 2020
Thanks,Big, what brought clearance issue to mind was bottoming out the day I bought it when loading onto pickup truck w/ramp. Needed help lifting back end at top of ramp. Will read manual more closely now. Peace, .......R
Old 5th April 2020
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
i'm runnin 10.5 short shocks and no ground clearance issue unless i'm hauling ass and scrapin pegs,haha.where is your oil filter located?if its where the generator was then its an alternator motor.my '85 race bikes an alto motor.split year in '84.my '83 road bike is an s&s stroker with over 50000 miles.any more questions about it?i run 60 weight synthetic oil in both of mine.good stuff.amsoil.belray sport trans fluid in both.more good stuff
Old 5th April 2020
ferretface's Avatar
Originally Posted by SHAKY DAVE View Post
my '83 road bike is an s&s stroker with over 50000 miles...i run 60 weight synthetic oil in both of mine.good stuff.amsoil.belray sport trans fluid in both.more good stuff
How do you separate the engine oil from the trans fluid???
Old 5th April 2020
When the oil pump changed there was no longer a transfer valve.....
Old 5th April 2020
SHAKY DAVE's Avatar
ferret the top big bolt on the primary cover is the filler for the trans.to check level stand the bike up as straight as you can.theres an allen bolt about forward of the middle(not one of the lower cover bolts)that's almost level with the front nut.while your filling watch the level hole.when oil starts to seep out stop your filling and let it go then put the bolt back in when the drizzle stops.man you know where to got to put oil in the oil tank.have fun.remember to put a pan under the left side case while its draining or your gonna have a giant mess.and don't let the bike fall down.i put a piece of 2x4 under the kick stand and turn the front end to the left
Old 6th April 2020
ferretface's Avatar
..."60 weight synthetic oil in both of mine.good stuff.amsoil.belray sport trans fluid"...So that's just one oil, not two???
...And I use two 2x4's...
