0 Chinese S&S carbs
0 "S" model specific Q&A
Last Post: vagrant318
0 Do you use a bike cover?
Last Post: ReddTigger
Last Post: Vic8028
0 N65C or N65A
12 Crankcase breathing?
Last Post: mikaelson
0 Sportster Fork Upgrade
Last Post: Redbeard2
Last Post: 45Brit
Last Post: 45Brit
0 Tires for "Rubber mount XL" poll.
Last Post: SLW210
0 New shocks on and old frame?
Last Post: Ted Town
0 Highway cruise speed
Last Post: lespaul6
0 Tappet blocks and tappets
Last Post: Scott
0 Turbo Iron 883
Last Post: Ghostdog
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Rear sets?
Last Post: bordens
0 Ground Up Beginner Build
Last Post: Paul.W
Last Post: PetesPonies
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 7th April 2020
AKL1 AKL1 is offline
Sportster/Buell Year: 1966
Other Motorcycle Model: H-D FLSTFI FATBOY
AKL1 is an unknown quantity at this point
It doesn´t seem to have any number on the belly.
I´ll try to clean it up and check more closely.
Old 7th April 2020
Case numbers can be a bit crazy. Here from a 1969 that I had some years ago...
Old 9th April 2020
Is it useful information that the electrical system is 6V?
Old 9th April 2020
For clarification, I maybe should tell a little bit more about me and the bike.
I recently bought this bike. I was told it's a 1966 as myself and I thought it would be fun owning a bike from the same year as I'm from.
I own a 2006 Fatboy too, but the Sportster is the first bike with old-timer construction and kickstart I've had. My plan is to take it apart and clean it up and fix it. I know the former owner had his share of problems with it. most of it, I reckon, because of it's Quicksilver carb.
I would like to keep it as original as possible, but if it's a kind of "mixed" bike anyway, I may do a kind of classic bobber instead.
As I dont know much about ironheads yet I guess I´ll need help and advice occasionally.
Old 9th April 2020
yoshi's Avatar
yoshi yoshi is offline
Sportster/Buell Year: 1971
Sportster/Buell Model #2: FXRS-SP
Sportster/Buell Year #2: 1985
yoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud of
I believe 1965 was the first year for 12v
Old 9th April 2020
Originally Posted by AKL1 View Post
... My plan is to take it apart and clean it up and fix it...
My advice would be to get it running before you "take it apart". Start by fixing just the individual parts that need to be fixed to get it to run.
Old 9th April 2020
correct.iirc it was a pair of 6 volt batteries combined.12 volts total.
Old 10th April 2020
Nitro57xl Nitro57xl is offline
Nitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really nice
1965 was the first 12 volt Sportsters. Yes the xlh's had two 6 volt batteries in 65 & 66. Electric start appeared in 67.
Old 10th April 2020
I guess your philosophy is well thought Mick. I´ll do that. I know that the bike needs new plugs and spark plug cables. I have an idea that the Quicksilver carb is a hard one to figure so maybe I need to put on another carb. Which one will you recommend?
Also I tried to kick it when I had got it home in my workshop. I then puked oil out of the bottom breather pipe. What should I make out of that?
Old 10th April 2020
Carbs? Just about anything but QuickSilver... Go to this link and search on carb. http://xlforum.net/forums/showthread.php?t=465866
Oil puke = wet sumped. Normal for most bikes after sitting for an extended period. Dr dick had a really good thread about pumps. Maybe someone can find it.
Hazmat Life
