0 95 tank on a 94
Last Post: Tipofthelake
0 73 XL 1000 Sportster - SOLENOID BYPASS
0 Headwork
Last Post: joes95bobber
0 WTB NOKK needle...
Last Post: lespaul6
Last Post: FiftySixer
0 theNeckerCube's Problems (Exhaust, Carb, … ?)
0 80 xl1000 oil not circulating?
Last Post: pucketprutectah
0 Yearly Allotment of Miles
Last Post: Skeezix
0 Can’t go over 70mph
0 Oh these college kids
0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
0 ultima install without VOES
Last Post: supermotolew
12 Crankcase breathing?
0 Tranny oil
0 Parts
0 Mikuni Knock Off "REVEALED" !!!
0 Why such heavy oil in Sportster?
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 23rd February 2020
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
Default Bigger rear Pulley
I have a a bigger rear pulley on my 1200 no change at front ,
so what difference does it make from a standard pulley???
i,ll try and get the size of new one when i can
more reduction so it should pull the machine harder.
i believe ironmick has the gearing combo list.
need to check speedo error and remember to adjust if you do not recalibrate
Thankyou for reply,.
How do you recalibrate the speedo??
Old 24th February 2020
kitabel kitabel is online now
Sportster/Buell Year: 1989
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
Never mind
Folkie Folkie is offline
If you don't know what difference it makes, why did you change it? I would have thought you'd answer that question before making the change.
rejeanprimeau's Avatar
You need a dealer or a TC88A to recalibrate your Speedo.
Hello Folkie,
i changed pulley because it was the one for my new wheels
i wasnt after more speed or or accelleration im not going too mess about with the engine apart from a new clutch.
I and mechanic think my engine has been rebuilt because all head bolts are new and the cylinders are spotless ,
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Year #2: 2019
A correct new rear wheel should have had the correct 68 tooth pulley. IIRC, the next size larger Harley Pulley would be a 70 tooth.
my wheels And you would not believe ,how many have asked where i bought them from.
i had aux lamps a new air cleaner new four pot front brake all chrome switches new plugs and wires and new belt
i love it
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Year: 1974
What rear turn signals are those? I don't thinl I have seen them like that before.
