0 Rocker Box Bolts & Torque
Last Post: Bone
0 Clutch Spring plate poll
Last Post: bimbo
0 Black Bike Bible
Last Post: Beelzeboss
0 Stabliser Tie-link 16232-04
0 Celebrating Sportsterpedia's Third Anniversary
0 Who's still riding???
Last Post: Popgadget
Last Post: oupa
Last Post: krono
0 Curious question (Wheelies)
Last Post: oupa
5 Jiffy Standing
Last Post: gpydeski
0 In Tank Oil Filter?
0 ******* usps
Last Post: oupa
Last Post: rurlndum
0 Her indoors
Last Post: kobra50
Last Post: FuriousGeorg
Last Post: 308bever
0 1979 XLH restore or not?
0 Free Shipping on Suspension from DK Custom - Limited Time
0 Limited Time- Savings Code on Comfort Parts from DK Custom
0 Limited Time- Stage I Savings Code from DK Custom
0 ***DK Custom-Universal Fit Stealth LED Front Turn Signals/Running Lights***
hillclimber (69), burtondl2 (51), Cet (49), hagar71 (48), ShaneWolfe (47), grizdiesel (42), Confused89 (34), RAIDER0372 (33), spamer80 (33), svwannabe
Old 18th January 2005
Lukas O Lukas O is offline
Lukas O has disabled reputation
Default Ignition module
What is the diference between 883 ignition module and 1200?? Are they the same? Is it true that the factory 1200 has a lower rev limit (5,200 rpm) in the
ignition module than the 883 (6,000 rpm). Please explain if I have to change module in my 883 to 1200 conversion, or maybe just use old one and change settings??
Ride safe!
Lukas(from Poland)
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
WHat year is your bike???
My bike is 883 hugger from 1997.
stevo's Avatar
OK.. I'll have ta go back thru my notes to check on the rev limits...
But I do recall the advance curve is a bit faster on the 883 module than the 1200 from memory..
I've done quite a few 883-1200 conversion and never worried about changin ignition unless we were goin all out with flat tops and bigger cams and head work....
A mild build is no prob as you can adjust the timing with the hall sensor anyway..
Old 20th January 2005
marco883's Avatar
marco883 marco883 is offline
Sportster/Buell Model: Sporty 883
Other Motorcycle Model: Ducati 900 Monster
Other Motorcycle Year: 1998
marco883 is an unknown quantity at this point
Hey Stevo,
On a mild conversion (dished 9.5:1, stock heads) '02, how much would you adjust timing? Will advance be OK at upper R's?
stevo's Avatar
A few ways to set timing......
MPH figures down a drag strip ... will give ya the best top end..
Dyno figures ... again max power
The main thing I'd be looking for is low to mid acceleration....as the 883 curve is a bit more agressive than the 1200's
Get it jetted close and then ya wanna go for a ride and get it warm..
crack the throttle in top from around 1800 rpm...... keep sneakin a bit more advance in until it just starts to "ping" then back it off a couple of degrees...
another check is you'll feel the engine run a touch rough as the ignition advance becomes too much.....
If you experiment you'll gaina feel for what I'm talking about...
To adjust it drill out the 2 pop rivets and remove the cover...
Mark the plate and the housing with either a permanent marker or a scriber...
Movin the plate clockwise advances the timing and anti clockwise retards it...
Let us know how ya go...
Thanks Stevo for replying! The only one thing I need now is start the motor and test run (but still snowing outsde! brrrr)
Similar Threads
'Initializing' a new SE ignition module? > Turbota Sportster Motorcycle Electrical and Ignition 43 24th October 2013 17:36
SE ignition module / Start problems SilverSporty Sportster Motorcycle Motor - Top End 24 11th October 2008 16:59
SE Ignition Module eagle101 Rubber Mount Sportster Motorcycle Talk (2004-2006) 13 21st February 2006 13:14
Ignition module installation madisonlink Rubber Mount Sportster Motorcycle Talk (2004-2006) 2 28th February 2005 19:08
