0 mid controls
Last Post: kitster
0 little rock
Last Post: kitster
0 Front cylinder noise
0 Clutch issue
Last Post: kas
0 900 dual carb front head
0 Ignition question
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 1200S cam comparisons
Last Post: Saint666
0 I'm going nuts (Adjusting Fuel Mixture)
Last Post: Another.Mike
0 New acquisition
Last Post: heyshott 81
5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: Slytat
0 lucas oil additive....
0 Runs rough on highway.
0 Tires for "Rubber mount XL" poll.
Last Post: Bryan83taco
5 Summer time heat
Last Post: Jarlaxle
0 Bendix / Zenith questions
Last Post: The Doctor71
0 Lacing a 21 inch wheel to a 19 inch hub
0 What is the best '70's Ironhead to restore
0 Modified heads
Last Post: mrmom9r
Wild One, Bugs (66), Blazer (63), OnDVirg (63), Buggyboy (60), TheChimp (45)
Old 11th April 2005
kntalan's Avatar
kntalan kntalan is offline
kntalan has disabled reputation
Thanks for the info maddog.. I am looking at the crane HI-4. Will this work in my sporty? Thanks for all the help I really want to get the right one the first time.. Here is a link to the one i am looking at..
http://www.jpcycles.com/productdetai...&page=&search=
Have a good one...Tom
Old 11th April 2005
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to behold
Yup .. that'll do ya... and with it bein Dual fire ya don't need new coils
Old 11th April 2005
kntalan's Avatar
Thanks Stevo... before i purchase it, What is your opinion on the nosecone set-up? Should i, or would it be better to go with like the dyna 2000hd set-up. And if you recommend the dyna 2000hd do i need the 7 to 8 pin adaptor.
Thank you again...Tom
Old 12th April 2005
maddog's Avatar
maddog maddog is offline
Sportster/Buell Model: Hugger 883/1200
maddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura about
kntalan...Stevo's right, as usual...but consider this. You'll already be half way there if you get the Hi-4 that is swithcable between single and dualfire.
You can run your stock coil in the dual fire mode, and at a later date get the single fire coil when you can afford it.
There is no difference in performance from about 3k to redline, BUT, when you go single fire the motor runs smoother below 3k and you eliminate a major cause of low rpm carb popping..You also extend plug and plug wire life.
Harley did this 'cause it's cheaper to run one coil. The "Wasted Spark" serves no useful purpose to the motor. It simply is NOT the way to to run a motor.
How many cars have you ever heard of that fire all their plugs at the same time?
Night Train + Street Fighter= NIGHT FIGHTER
MY GALLERY
"It's just a Sportster, but I'm saving up for a Big Twin."
That's like saying...
"It's just a Corvette, but I'm saving up for a Station Wagon."
STEPHANIE FELD
HOT XL MAGAZINE
SUMMER '97
He was asked, "Why do you ride?" He considered the question carefully for a few moments. "The Lean", he replied.
Similar Threads
'Initializing' a new SE ignition module? > Turbota Sportster Motorcycle Electrical and Ignition 43 24th October 2013 16:36
SE ignition module / Start problems SilverSporty Sportster Motorcycle Motor - Top End 24 11th October 2008 15:59
Ignition module installation madisonlink Rubber Mount Sportster Motorcycle Talk (2004-2006) 2 28th February 2005 18:08
Ignition module Lukas O Sportster Motorcycle Engine Conversions 6 20th January 2005 12:45
Sportster/Buell conversion ignition question?? sportster883r Sportster Motorcycle Engine Conversions 6 7th January 2005 04:43
