0 Winter Storm Warning
0 Is this 1200R worth $4500?
4 The no-debate OIL POLL
Last Post: bplinson
0 Celebrating Sportsterpedia's Third Anniversary
0 68 xlch wiring
Last Post: Zach68
0 joyride memories xlx ironhead
0 Does Synthetic Engine Oil cause Higher or Lower temps at the oil tank?
Last Post: Sportycus
0 Mustang's new seat? Anyone tried it?
0 timing troubles!
Last Post: The Doctor71
0 Photos: King Peanut or Regular Peanut tank?
Last Post: Calcustom
0 XL883L 2006 coughing and backfiring
Last Post: Bama Lee XLC
0 How many helmets?
0 Clutch Spring plate poll
Last Post: bimbo
0 What oil temp do you run
Last Post: JKKO
Last Post: 1977iron
0 Who's still riding???
Last Post: 1977iron
0 Bushing alignment
0 Helmet poll
0 Pull cam cover for powder coating
Last Post: spoon
5 Jiffy Standing
Last Post: rurlndum
steve yorke (61), edman (53), Hudsonator (51), kozman32 (51), R3DN3X (49), gmcsid (48), mitch (43), Gotenfan (29)
Old 7th December 2004
Turbota's Avatar
Turbota Turbota is offline
Question 'Initializing' a new SE ignition module? >
I am ready to install an SE ignition module with a 7,000 rpm rev limiter in my 04 Sporty prior to a cam change and head work. Nallin told me that the bike would need to go to the dealer to get the new module 'initialized' with the H-D diagnostic computor (or whatever it's called). I told them about this procedure that was once posted on our old message board ... He was unaware of this procedure.
Ok ... Has anyone here actually used the procedure below on there 04-05 Sporty after installing a new SE module?
Does it have to be done and does it actually work? (I don't want to drag this biker to the Stealer)
_______________________________________________
Initializing 04 XL1200 Ignition Module
Please note that you have to perform steps 5-7 a total of 3 times. Step 6 takes 10 minutes each time and the ignition and lights are ON. This takes a total of 30 minutes to complete. I would suggest that you disconnect the headlight to reduce the drain on the battery.
1. Install the new ICM (Ignition Control Module)
2. Set RUN/OFF switch to RUN. - Verify that the security lamp is not blinking (vehicle is disarmed).
3. Turn Ignition key to ON. - TSSM enables starter relay.
4. Press starter button 1 time. The vehicle will start and stall. No stored password for new part causes bad password DTC, fuel flow is stopped.
5. Wait 10 seconds. Security Lamp will illuminate. ECM enters password learning mode. If Ignition key is cycled learning mode exits.
6. After 10 minutes, ECM completes auto learn mode. Security lamp turns off.
7. Quickly turn Ignition Key Off then ON.
8. Repeat steps 5-7 two more times.
9. (last time) Turn Ignition Key off. Wait at least 15 seconds before turning Ignition back on.
Password learning is complete
04 XL 1222R
Old 8th December 2004
sportymark's Avatar
sportymark sportymark is offline
Other Motorcycle Model: Yamaha XJR1300
sportymark is an unknown quantity at this point
Turbota,
I will speak to my my Chris today (he is the service manager at Thames Valley Harley) and ask.
1200RSC - Roadster Sport Custom (Roadster Base, Sport suspension, SE Stage 2 engine and Custom bodywork)
"This man is depriving a village somewhere of an idiot"!
sportymark's Avatar
Turbota,
According to the dealer these units are pre-initialised - the are plug-n-play!
Turbota's Avatar
Thank you Mr. Mark !
Old 9th December 2004
SportsterSpive's Avatar
SportsterSpive SportsterSpive is offline
Sportster/Buell Model: XL883 w/NRHS Stage 3 1250
Sportster/Buell Model #2: XB9SX CityX
SportsterSpive is an unknown quantity at this point
They are not plug and play. Your bike won't start if you just plug it in. And, the module can only be used with the bike it was initially synced with. I used the proceedure with my Nallin kit and H-D ignition module. Worked great.
--Sean
"The Rubber Rocket" - 97.4 hp/80.9 tq
'04 883/1250 Stage 3 NRHS Conversion
Forcewinder, Mikuni HSR42, Supertrapp 2-1, SE .575 cams, TC88A ignition, 1200S forks and shocks, Chainsikle rear seats, eBay Clip-ons
"The City Hero"
'06 Buell XB9SX CityX
Buell Race kit, some othe things
Old 11th December 2004
TechRep's Avatar
TechRep TechRep is offline
TechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of light
I had to do the same when I installed the SE module. Used the proceedure and it worked for me.
I asked Daytona Twin Tec if this was needed for their TC88A, and was told it was not required.
Turbota's Avatar
Just installed my SE module. The engine ran for about 1/2 second and stopped.
Did the initialization procedure above and everything is good with the world.
Very good idea to unhook your headlight. 30 minutes is a long time to burn that headlight bulb doing this procedure. Don't know how long the battery would last.
Ron,
barry1967's Avatar
barry1967 barry1967 is offline
Other Motorcycle Model: 2005 FXD Chopper Blue
barry1967 is an unknown quantity at this point
Correct, Twin Tech is plug and play.
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
TechRep's Avatar
Cool... Hopefully I'll be "plugging and playing" by Monday. If my "honeydew" list gets completed, I can work on the bike... I think she's going shopping and I will have lots of time!!!!
Old 19th January 2005
Gone Gone is offline
Damn! Should have read this post first! Would have saved me a lot of agravation and cursing of both Mr. Harley and Mr. Davidson! Will go back an try the solution offered above...
2004 883XL
Similar Threads
SE ignition module / Start problems SilverSporty Sportster Motorcycle Motor - Top End 24 11th October 2008 16:59
SE Ignition Module eagle101 Rubber Mount Sportster Motorcycle Talk (2004-2006) 13 21st February 2006 13:14
SE adjustable ignition ShortBus Sportster Motorcycle General Discussion and Problems 3 15th April 2005 04:22
GOD what a PITA the SE ignition password re-learn is!!!!!!!!!!!! Joshuasws6 Sportster Motorcycle Motor - Top End 1 13th April 2005 15:47
I highly recommend the SE ignition module... Rondall Sportster Motorcycle Motor - Top End 16 17th February 2005 23:39
