Last Post: rezchug
0 Happy Birthday 'jzink0883'
Last Post: Lowe175
0 Marshwood Vale, 17th June 2019
0 Wet sumping?
0 Been Sitting For 5-10 years; Starts, But Dies
Last Post: Feskerlars
0 Front brake is terrible
Last Post: Hopper
0 Poweraythor alternator conversion
Last Post: saddlebagrail
0 2014 swingarm axle in earlier rubber mount
Last Post: jazzman
0 Does anyone run the Machinist Mike “hydro clutch?” If so how do you like it?
Last Post: Rolli
0 Gave up and made a bigger fuel tank (see pic)
0 Which cams ?
Last Post: gusm2
0 The White Bike is the Right Bike Thread.
Last Post: A Seabee
0 need service information for my '71 Ironheqad
0 Torque Cones
Last Post: Model H
0 Stator wire hot!
Last Post: oldboy
0 will not start
Last Post: 01rk
Last Post: sprink
0 For Sale: 2012 XR1200X
Last Post: joes95bobber
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
Old 19th September 2018
jordan1200's Avatar
Default Cylinders and static compression checked. Advise?
Ok I did a static compression test last night and got 170 psi per cylinder (engine cold).
Seems a bit low doesn't it. Before the teardown and piston replacement I had about 180 psi.
I have about 1200 km. on the top end. I did a check at about 800 km and I got 180 psi.. (cold engine).
Now I took my telescopic camera into the combustion chamber and the front cylinder looks pretty clean still. The rear has me concerned. See pictures
Front cylinder first picture
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
well if you just replace parts, it might take awhile to seat in. so a ?
did you do a bore? or just a hone?
did you check for taper?
jordan1200's Avatar
Bored 0.010" over with factory Buell pistons
jordan1200's Avatar
Any thoughts on the pictures?
Old 21st September 2018
had to say over the net
but
hd cyl's do not run the same, look at how they are fueled
i run diff heat ranges to even out the two plug wise
