0 Moto Guzzi V9 Bobber debut
Last Post: Bone
Last Post: Bone
0 Best Tires to get 2017
Last Post: Four Speed
0 Replacement Fuel line?
0 Shotgun Porn
0 Hello from 1970s Wisconsin!
0 What do you think the wet weight of the Pan America will be?
Last Post: jammantoo
Last Post: bimbo
0 Cylinders and static compression checked. Advise?
Last Post: jordan1200
0 mode of failure
0 Cobra RPT Intake
Last Post: FearTheBeard
0 Dead battery cells - 1997 sportster 883
Last Post: jharback
Last Post: Vohnsen
Last Post: SoonerSport
0 Gravydog crashed again.
Last Post: ed_in_az
Last Post: salveson
0 getting this 78 back to the way it should be.
Last Post: DirtyCory
0 TC88A makes me smile until WOT
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: rj2
0 fat man on a sportster
0 Fitting 2003 sportster seat to 2004 sportster
Last Post: MudDigger
Last Post: SteveK
0 Electrical Problem with '77 XLH-no power
Last Post: Tator
0 Seats
Last Post: Beelzeboss
0 The Harroway: Sefton Warren To Powderham Castle
ziggyhd1 (60), greven (58), bliynd (33)
Old 4 Days Ago
Diogenes415's Avatar
Diogenes415 Diogenes415 is online now
Originally Posted by John Harper View Post
Doesn't that clear line get stiff and discolored? My buddy got some for his dirt bike and it got stiff and brown within weeks and was leaking from the carb connection. I just use 1/4" regular black fuel line on my bike. Maybe tygon is different?
John
Are you sure it was Tygon he used? I've seen people use vinyl tubing thinking it's the same thing and that crap hardens within weeks, as you've said. Mine have lasted years and have remained flexible. Tygon feels more like surgical tubing if anything... although surgical tubing isn't fuel safe, AFAIK.
Nope, it's a Sportster.
Old 20 Hours Ago
Sportster/Buell Year: 1991
Ok, I'll look into it.
John
Old 19 Hours Ago
John
It's sold in black, grey, clear and yellow translucent, maybe even more colors nowadays. I've been working off of the same 50' roll I bought over 20 years ago.
Tygon fuel line at Summit Racing.
Old 18 Hours Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
harley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant future
What ever you use i would put it inside a length of armaflex tubing to protect it from the heat of the heads/barrels. And as already suggested, go to a car accessory shop, Harley prices are crazy for these items.
Old 11 Hours Ago
jordan1200's Avatar
Thanks all
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
Old 9 Hours Ago
My buddy bought a foot of grey 1/4" fuel line for his two 2007 Yamaha XT 225s. I think it is probably Tygon. I changed both bikes lines plus small inline filters. One bike had some 3/16" line from my scrap box, and the other, the blue line we tried previously. It leaked on the other bike so I used 3/16" line. That issue is still a problem with the Tygon. Yamaha says it should be 1/4" ID line to be used. Identical bikes.
Seems to fit a bit looser than I would like (1/4" fittings) compared to my regular 1/4" line, and one of his petcock fittings seems a bit smaller than the other (and leaked again!), so I had to go back to some old 3/16" line from petcock to his inline filter. I'm not sure he's got the right clamps, either. Maybe we can find a bit smaller diameter on Ebay.
He paid $6 for a foot of this stuff. I think my regular black fuel line still works for me.
John
Old 1 Hour Ago
Four Speed Four Speed is online now
Sportster/Buell Year: 1988
The main issue with Tygon for me is that it is not particularly heat resistant even the LP110 speced for fuel lines. Similarly with "black rubber hoses,"
Some are much better at handling ethanol and heat than others. It is best to check the SAE spec to be be sure before installing it between Harley cylinders.
