0 My Sporty got a little sister!
Last Post: Haegar
3 post a pic of your AMF sporty
Last Post: khav
0 Broke fin on head.
Last Post: VaFish
0 Keith Black 10:1
Last Post: 1HD4CJM1X4K
0 BowlingGreen Fall races
Last Post: hexnut
0 Looking into Full Face Helmets. Any ideas?
0 DIY 12v Electrical Outlet
0 Harley noob
Last Post: Bone
10 My 1982 XLSA Build Thread
Last Post: Prof Rene
0 Shotgun Porn
0 Ultima reprogrammed with Dyna curves
0 Icon Thriller helmet
0 How to install a rear chain tensioner (and where) ?
Last Post: Four Speed
0 upper front engine bracket bolts
Last Post: redjack
Last Post: Yakcm2
8 Sputtering Problem and trying to diagnose
Last Post: Screw Loose Dan
0 Crooked crankcase
Last Post: T_worth
Last Post: spitfirechopper
0 Range With EFI 4.5 Gal Tank
0 S&S Cycle Hooligan 2-2 Exhaust
0 Headlight Modulator
0 1960 XLCH in the UK
Last Post: sleighcrane
0 Supertrapp 2:1 fit issue with Pics
Last Post: robbie202
Last Post: cotton1
0 October 13th - Ironhead Rider Gathering: PA/NJ (Fall 2018 G.B.B.)
Last Post: Magneto Sportster
Old 24th April 2018
Dave L's Avatar
Dave L Dave L is offline
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant future
I just read the part about not taking the drain plug out at the front of the engine. Is it really that bad? I am guessing that these do not have a level of oil in the engine crankcase?
Old 24th April 2018
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
There are various plugs on the bottom of the crankcase halves depending on the year. There is one that I believe is directly under the flywheel on some early models. That one is not a drain plug, but is a part of the manufacturing process. If you remove it you risk wrecking the threads - this cannot be repaired without dismantling the entire engine as there is not sufficient space for a tap.
I believe that your 1985 does not have this plug, and any plugs that are there can probably be removed. However, best to take some clear pictures, post them here on this forum, and seek advice.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 24th April 2018
Dave L's Avatar
Ok. Thanks Mick
Old 25th April 2018
IronMick's Avatar
This pic of my 1978 shows an example of the crankcase numbers, and also of an extra plug on the bottom of the cases which is safe to remove - it is an Allen key bolt. I believe the unsafe ones are all 1960s and possibly some early 1970s, but I have not had the opportunity to see any so I really do not know...
Old 25th April 2018
Dave L's Avatar
I looked under there last nite there is nothing. I did see an allen I believe. I read the manual. Should have before asking. They say its not necessary to drain the crankcase as it does not accumulate oil.
Old 25th April 2018
IronMick's Avatar
Originally Posted by Dave L View Post
... They say its not necessary to drain the crankcase as it does not accumulate oil.
By some magic, the oil always seems to appear in the oil tank
