0 Brake light stays on
0 What is this?? 07 efi 1200 weird box
Last Post: Bob F
Last Post: Bob F
Last Post: jordan1200
0 05 and 73
0 Magneto CH PORN thread
Last Post: rickmodee
0 Diagnostic help
Last Post: BradX13
0 Another use for your Iornhead engine.
0 The norse Saga's, or Pia & Tores ramblings if you like.
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
0 Crusty Curmudgeon’s Sportster Dictionary
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
0 Throttle Cable Install Problem
Last Post: Turbo Sporty 48
0 S&S Stealth
Last Post: lucifer_mr2
0 Front brake won't bleed 1989 sportster
0 Not charging issue!
Last Post: tvon
0 HAMMERPerf 90" In the Works
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Last Post: brianbbs67
danfr danfr is offline
Sportster/Buell Model: 883
danfr is an unknown quantity at this point
Default Coil Replacement
Hey you guys! New to the forum here. I picked up a '93 883 with a 1200 kit in it. It's been a blast!
I'm heading out next month on a big road trip and am considering replacing my ignition coil. I would hate to be stranded and the coil that is on there is stock. I know the vibrations can really get to these coils. I've found the specs for the coil (Primary 2.5-3.1 ohms, Secondary 10,000-12,500 ohms). Should I be looking at a 3.0 ohm (DC6-1) coil then? I see Dyna has a few different coils and want to make sure I pick up the correct one. I searched through the posts and couldn't find a straight answer, hence posting.
Thanks!
Dan
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
The OEM coils don't fail often. I really wouldn't worry about it if it has no problems currently. I'm rocking this one and have for a while: https://www.jpcycles.com/product/380...ment-31614-83a
Old 6 Days Ago
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
+1
Especially if the ignition key is not left on overnight.
Old 6 Days Ago
Take some time and go over the essentials:
Just Bought A Used Sportster - Checklists For Making It Right
Sportsterpedia - Check Your Battery Cables
Sportsterpedia - Check your Alternator/Stator
Sportsterpedia - Coil Info & Testing
Sportsterpedia - Clutch Adjustment - Why & How
Make a record of what you measure for voltages and any other measurements... Keep that for a reference in case of issues on the road or in the future...
Good luck on your road trip... Be sure to take some pictures and post them to the forum...
2 Relax
