0 Poor running bike trouble shooting help
Last Post: Racepres
0 what size motor?
0 Mikuni trouble
Last Post: gusm2
0 you tube screw up
Last Post: thefrenchowl
0 West Virginia fall run 2022
Last Post: joes95bobber
0 Allegheny National Park III
0 Compression height -- am I right?
Last Post: xlh59
0 how do I put engine back in frame
0 KT - 2022 - Show A Little Backbone
Last Post: DrMotorcycle
0 Not Running Right
0 Instrument of Expression, the next chapter of the Sportster legacy
Last Post: Blackbenny
0 FTC - Harley-Davidson - Customers’ Right to Repair
0 Seeking information on long lost "race" parts
0 Cutting off Mufflers...Open Pipes
0 eBay racetech emulators?
0 Spool Wheel lacing
Last Post: mofosheee
0 Cafe Bars/Drag Bars/T Bars
Last Post: Dave L
0 Brake drum out of round
0 Will earlier year rear sprockets fit on an 06?
Last Post: Sirrom1
0 1981 XLH Getting Recranked
Old 18th January 2022
Jhbox13 Jhbox13 is offline
Sportster/Buell Model: 1958 XLCH
Jhbox13 is an unknown quantity at this point
Default SOLVED: Help me ID this bike
EDIT: Thanks for the help!
First things first: I just got this bike from a crowded garage from a local guy, and I DID NOT CHOP OR HARDTAIL IT, it was like that when I got it. I personally hate the idea of doing that to such a classic bike, but it looked like a neat project and I may try to put it back close to stock. Now that that is out of the way.....
Got this bike last week. Guy was selling it as an XL with no papers, same old sad "I was going to get it running but I have too many projects" story. The engine serial reads number (see picture below) but there were supposed to be 239 made in 58 and the serials start at 1000, seems like too high.
https://imgur.com/rhiUmXA
Now, its definitely a 58 judging by the matching belly numbers (see below).
https://imgur.com/R7bPTDI
https://imgur.com/zpRLdsb
Thing is, that would make it either an XL, XLH, XLCH, or and XLRTT. Production numbers are as follows:
XL: 579
XLH: 711
XLCH: 239
XLRTT: 26
Notice how none of them go up to? That has me scratching my head. How is there a serial up to if there were no XLs of any type produced in 58? Yeah maybe the CH was stamped in later, maybe, but the numbers look spot on from the samples I've seen online and fit HD's pattern according to the VIN ID book I use. This thing is kickstart only, which I think excludes XLH, and had a magneto and horseshoe oil tank which does fit the profile of an XLCH. The frame date stamp is missing thanks to the ape who decided to cut up the frame, or I would have included that too.
So what's your best guess at what this actually is? Not that it will matter much in the restore, but its killing me not to know. I really appreciate any help here. Luckily I have nearly all the old parts from it, including front end and swing arm so it may return to near former glory at some point.
Sportster/Buell Year: 1971
Other Motorcycle Model: 1988 BMW K75
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
Without any ownership paperwork you will most likely need to get the bike inspected. The process varies by States. I wouldn't spend any time or money on it until you know for sure you can get a title.
rejeanprimeau's Avatar
Production number 1000 to what ever, your is the 763 built that year. The sequence don't go with model.
I've already got the title bond paperwork submitted, I'll have a bonded title by the end of the week.
Ok, that makes way more sense. I had thought about that briefly but without anything to go on I thought I was on the wrong track.
