Keep & Kill
o f (77), john648 (64), Ron Bizzle (64), IronHead78, drdisturbo (59), memikeni (54), Thomas Covenant (52), karl williams (51), parrothead306 (51), djbock (51), mr fandangle, tec_sportster (44), plynch113 (43), blackbob23 (41) |
18th January 2022
Posts: 1 Sportster/Buell Model: 883XL Sportster/Buell Year: 2012
Speedometer
Speedometer was working intermittently but now is completly dead. Does the VSS have anything to do with it or my speedometer needs to be changed.
18th January 2022
Posts: 2,772 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2013
Check for codes, a VSS code wouldn't necessarily turn on the Check engine light.
The VSS sensor shares a 5 volt reference with several other sensors, TPS, TMAP and JSS(international models)
Harley Trouble Codes
24th January 2022
Posts: 14,080 Sportster/Buell Model: 1200S Sportster/Buell Year: 2002 Sportster/Buell Model #2: XLH883 Sportster/Buell Year #2: 2003 Other Motorcycle Model: 2022 Triumph Street Twin
It may be a faulty vehicle speed sensor or wiring to or from that sensor. Have you first checked that you have 12 volt power to speedo position one which is orange (ignition) and three which is brown/gray (accessory)?
Also do you have good continuity to ground on the black wires at position 7 and 8?
What is voltage to VSS?...from ECM position 14 r/w, changes to bk/r at VSS...should be 5 vdc
Next step would be VSS output on bk/be wire to ECM position 33 per the Sportsterpedia link in IXL2Relax's post 3.
http://xlforum.net/forums/showthread.php?t=1869053
Speedo (numbers are left-right)
12 blank
11 trip switch bk (to 8)
10 blank
9 fuel y/w (formerly blank on 2004-2006)
8 trip switch (to 11)
7 ground bk
6 accessory o/w
5 battery bn/gy
4 blank (formerly security on 2004-2006)
3 blank
2 data lg/v
1 ignition o
