0 Poor running bike trouble shooting help
Last Post: Racepres
0 what size motor?
0 Mikuni trouble
Last Post: gusm2
0 you tube screw up
Last Post: thefrenchowl
0 West Virginia fall run 2022
Last Post: joes95bobber
0 Allegheny National Park III
0 Compression height -- am I right?
Last Post: xlh59
0 how do I put engine back in frame
0 KT - 2022 - Show A Little Backbone
Last Post: DrMotorcycle
0 Not Running Right
0 Instrument of Expression, the next chapter of the Sportster legacy
Last Post: Blackbenny
0 FTC - Harley-Davidson - Customers’ Right to Repair
0 Seeking information on long lost "race" parts
0 Cutting off Mufflers...Open Pipes
0 eBay racetech emulators?
0 Spool Wheel lacing
Last Post: mofosheee
0 Cafe Bars/Drag Bars/T Bars
Last Post: Dave L
0 Brake drum out of round
0 Will earlier year rear sprockets fit on an 06?
Last Post: Sirrom1
  #61
Old 25th January 2022
t120r t120r is offline
Sportster/Buell Model: xl883r
t120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rough
Originally Posted by gl90hog View Post
Interesting! One thing to try is to add a missing tooth, but that's kind of hard now, since it is not really "missing", but added, right? Just to see if uSquirt will actually trigger with no errors. While playing with various sensors and wheels I found it to be rather... Picky
I have good, strong signal from the harley sensor and 1018 timing wheel. I'm told that the 12-1 pattern wil work fine and even a 12-2 might be easier starting.
Old 26th January 2022
Originally Posted by t120r View Post
Call Hammer Performance. They make their own steel timing cup. I was told getting a custom tooth pattern was not an issue.
Hammer just called me and said they have so many timing cups on the shelf that they can't see making any for a few months. You'll have to make your own or get one made at the machine shop.
Old 1st February 2022
gl90hog gl90hog is offline
gl90hog is an unknown quantity at this point
Too bad. Back to improvisation
I just received my BMW G650 TB, it looks good, almost new. 45 mm diameter (bigger than CV carb). Idle valve has a stepper motor hence cannot be controlled by microsquirt, but no matter, Buell TB does not have one on the other hand. Single injector is small, I will probably upgrade it, although for low rpm torque might be ok - I shall see
In few days. I will test it with the bike on the dyno, to set the baseline before installing the turbine
For this step I shall use existing Ignition and just tap the coil
Old 2nd February 2022
Sure it can. You just need this:
https://www.efisource.com/wp/shop/mi...epper-adapter/
Probably cheaper than adapting/buying an external pwm IAC.
True, there is this possibility I knew of - I was meaning not directly being capable of! Not sure it's worth the trouble, I will see
It's not the extra bucks, what I am more interested is where to squeeze all the extra elements + wiring. Already considering buying a new LiIon battery and replace my... newly installed battery, just to have more space to hide electronics
Hi All
I finally got around with fitting a BMW G650GS throttle body (single injector), and got it running with microsquirt.
It sort of runs, in the sense that it is not exactly constant, AFR is all over the place, but accelerates really strong.
The question is whether anyone has VE tables suitable for a Harley, no matter the absolute values, I just need to see how the values distribution looks like so I can replicate it somehow? The autofill feature is totally off, and autotune seems to make tables worse than I did myself manually
Thanks!
