0 My 2002 Cafe Build
Last Post: 1904Sportster
0 Tire Size
Last Post: Scott
0 Cheers from Germany
0 Spokes and dual disc
Last Post: TonyGall
0 What jets do you use?
0 New XL1200L from Oakland
0 77 kicker engagement issues
Last Post: NHPS
0 A Day in the Life...
0 Mag wheel corrosion
0 Help identifying this Seat
Last Post: 83xls
Last Post: Jezebelle
Last Post: VaFish
0 Spokes or Mags
Last Post: Eric Von Zipper
0 Ultima ignition
Last Post: Randy_rots
0 Oil Pump Upgrade '86-'90
Last Post: BWP 5p
5 How'd You Pick Your Username?
4 What will 10 cents buy?
Last Post: Knuckles
0 ***DK Custom Products is Now offering the Black Headlight Grille***
0 1962 High Pipe Muffler
Last Post: murph1068
0 Front MC advise
Last Post: slcharger
bobman, eagle101 (71), nemosengineer@yahoo.com (62), Callao (62), Dweezil (54), Dnew73, JimmyHBS (43), Ulv666 (42), 883ccXL (37), jmr1283 (35), dtschrum (31)
Old 5 Days Ago
Sportster/Buell Year: 1974
needspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud of
Here's an observation about your bike. This may be or may not be an issue for you but in case you aren't aware harley felt that on earley 1000 frames starting in '73 that the rear frame section where the shocks mount wasn't strong enough and offered add on braces (part # 47087-74) that could be welded on to increase the strength.
Maybe the picture isn't clear but I don't see them on your bike,and you've mounted the shocks in a non stock position that would put more strain on the frame in that area.
When I bought my used '74 it had the braces. I'm not sure if they were add ons but there is a lot of welding spatter on them, so I'm guessing they aren't from the factory.
Maybe you've got them and I just don't see them. But if not you should keep an eye on that area for any bending or cracking.
Anyway here's a thread that shows what I'm talking about.
http://xlforum.net/forums/showthread.php?t=1383320
Old 5 Days Ago
JackPrice53's Avatar
JackPrice53 JackPrice53 is offline
Sportster/Buell Year: 1965
Other Motorcycle Model: Softail
JackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud ofJackPrice53 has much to be proud of
Originally Posted by Flame__ View Post
I absolutely love the simplistic rawness of this bike! Looks to me like the chain is pretty tight. I don't see any sag on that thing. Could it be too tight? Those output needle bearings might not like that.
Recall, a loose chain is a happy chain.
Old 4 Days Ago
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of lightSHAKY DAVE is a glorious beacon of light
pull that sprocket cover off and you'll see where the chain is rubbing.what front gear?23 they instruck you to clearance the chain.i use a dremel,works great.how old is the chain?you'll get a lot of side to side on a worn out chain and that will start bangin on stuff.replace it
Old 4 Days Ago
Gold Member's Avatar
Sportster/Buell Year: 1972
That bike has a lot of nice features.
- Marcus Aurelius
Old 4 Days Ago
ricochet ricochet is offline
Sportster/Buell Year: 1973
ricochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nicericochet is just really nice
Default Nice ride
This bike looks nice.
Needspeed, I can barely see using some imagination that the add on bracket may be there but welded in a smaller triangle than intended by the factory. I do remember in May of 73 when I received the recall letter thinking WOW they actually recall bikes too. Being a youngster I hadn't been exposed to such matters. I had got my XHL Feb 5th and thought oh boy, nice way to start the season. But it was a real quick fix.
ricochet
Old 4 Days Ago
dsw919's Avatar
dsw919 dsw919 is offline
Sportster/Buell Year: 1976
dsw919 is an unknown quantity at this point
The front sprocket is stock size, chain is brand new RK. As for the frame support brackets, it did originally have them but we cut them off. From what I gathered, they aren't necessary, but I'm sure it would be a good idea to keep an eye out for cracks or stress.
I went ahead and ordered some different shocks. At least I will know after installing them if the noise goes away.
Another note, I see a lot of ironheads that have what appear to be shovelhead shocks (the ones that have full covers). Many of them appear to be lower than stock. Is there a way to disassemble those shocks and make them lower? I like the way they look almost as much as my current shocks.
Old 4 Days Ago
doodah man's Avatar
i have that type of shock on mine and if mine were to be lowered by much i would have issues with the tire rubbing on fender parts. i want to say mine are 12" eye to eye.
Old 3 Days Ago
SHAKY DAVE's Avatar
and mine are 10" short shocks.no rubbin except with a worn out chain.he needs to pull the sprocket cover off and see where its rubbin
Old 3 Days Ago
dsw919's Avatar
I just measured my shocks, they are about 10.5” eye to eye. I will take off the sprocket cover soon and do some investigating, but its kinda hard to take it on any test rides now. Its about 25F outside now, and salty roads.
Old 2 Days Ago
SHAKY DAVE's Avatar
thanks for doin that man.you'll find the problem doin this
