0 My 2002 Cafe Build
Last Post: 1904Sportster
0 Tire Size
Last Post: Scott
0 Cheers from Germany
0 Spokes and dual disc
Last Post: TonyGall
0 What jets do you use?
0 New XL1200L from Oakland
0 77 kicker engagement issues
Last Post: NHPS
0 A Day in the Life...
0 Mag wheel corrosion
0 Help identifying this Seat
Last Post: 83xls
Last Post: Jezebelle
Last Post: VaFish
0 Spokes or Mags
Last Post: Eric Von Zipper
0 Ultima ignition
Last Post: Randy_rots
0 Oil Pump Upgrade '86-'90
Last Post: BWP 5p
5 How'd You Pick Your Username?
4 What will 10 cents buy?
Last Post: Knuckles
0 ***DK Custom Products is Now offering the Black Headlight Grille***
0 1962 High Pipe Muffler
Last Post: murph1068
0 Front MC advise
Last Post: slcharger
bobman, eagle101 (71), nemosengineer@yahoo.com (62), Callao (62), Dweezil (54), Dnew73, JimmyHBS (43), Ulv666 (42), 883ccXL (37), jmr1283 (35), dtschrum (31)
Old 3 Days Ago
Sportster/Buell Year: 1991
Not if she had to field dress it!
Was that near Flagstaff?
Took her and her guide almost all day to dress it. Lost one of the legs as it was under the carcass, meat spoiled. I believe there were near Flagstaff, but not sure.
JOhn
Old 2 Days Ago
Jollly Rogers Jollly Rogers is offline
Jollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond repute
Originally Posted by lespaul6 View Post
Regarding the float setting, does anyone have a diy trick for measuring the 15 degree angle? some type of clever device or trick when you do not have a proper calculation device?
This qualifies as clever in my opinion...
Find some clear vinyl aquarium tubing and temporarly substitute it for the float bowl drain hose. Loop it up higher than the carb. Open the float bowl drain screw. The fuel will enter the tube but find the level of the fuel in the float bowl. The spec is the top gasket line on the float bowl. If it’s off then tweak the float upper or lower as necessary. Hopefully the level will be correct and tuning will not be necessary.
Joe
Old 2 Days Ago
mwXL 2006's Avatar
mwXL 2006 mwXL 2006 is offline
Sportster/Buell Model: xl 1200c custom
mwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to behold
Here is a pic of the needle... I don't think? its stock.. I could be wrong. The clip is on the second notch from the bottom.
shouldn't the washers be on top instead of bottom? creates a richer condition on bottom of clip. Needle comes out much sooner. info from sportsterpedia gives numbers for stock applications of your carb
Xl 1200c custom 2006 carb.
42 CVP pilot 180 main
3 out a/f screw
V&H straightshot slip-ons
K&N Hi-Flow 587 air cleaner
Breather Bolts to air
Love to ride. Stay safe
Milt
http://sportsterpedia.com/doku.php/start Use it great info
https://postimages.org/ for your photos
Old 2 Days Ago
sportsterdoc's Avatar
The lower the clip, the more lift to the needle, with a richer mid-range and slightly effecting even the idle circuit.
Washers are normally under the clip to make it richer. On top has no effect, other than storage
Shimming the needle is one way to test changes to mid-range and many riders are satisfied with only shimming. However, the profile is not quite the same as replacing with a richer needle.
With the clip in the next to lowest position and two shims under it, it may be too rich, causing it to "blubber", rather than starve/balk/hesitate. It takes a good ear to tell the difference, but a small puff of black smoke may be a give away.
Old 2 Days Ago
...info from sportsterpedia gives numbers for stock applications of your carb
Yes
99-01 1200 carb is 27480-97
02-03 1200 carb is 27480-97A
Both came with 170 main, which is what was ordered from CV Performance.
I ended up with a 180 main in my California 2003 XLH883 (27495-96A 42/170 stock) to lower the oil temp for my riding...this increase may not be applicable for 49 state bikes...with a different carb, as a 2003 883 49 state bike came with a 27490-96A jetted 42/160...and I continue to think that there are differences between the carbs, in addition to jetting...otherwise why would a California carb, expected to be leaner, come with a 170 whereas a 49 state carb comes with a 160?
Bottom line for this thread (not that I have EVER contributed to thread drift!) for lespaul6 to start with a stock 170 main jet is quite appropriate.
Old 1 Day Ago
lespaul6 lespaul6 is offline
Sportster/Buell Model: 2000 XL 1200C
Sportster/Buell Model #2: 2002 XL 1200C
lespaul6 has disabled reputation
I'm at a standstill right now waiting for the parts to arrive... I probably should have ordered from CV Performance dealers as opposed to them directly... they are very slow. A dealer already sent the needle in the mail the next day!
