0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
Last Post: Fifty150
0 Hi from the UK
Last Post: toe
0 Looking for Baker XL6 Speed transmission or equivalent
Last Post: groovemeisterus
0 The One With The Goose Bumps
Last Post: Fifty150
13 Monoxide carbon CO emission test failed
Last Post: krono
0 Allegheny National Park
Last Post: BestCoastXL
0 Big Bore Guru's
0 Oil leaking :-(
6 'Royal Enfield', the little sport from...INDIA??
0 What happened to 6 speed transmissions and Sportgear?
Last Post: Bigshankhank
14 Need help deciding on tires
0 Invalid:
0 Got me a GPS Speedometer.
4 XL 2005, speedometer not working, code U1097
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: Crash7557
0 Easy start cam choice
0 WTF Happened
Zanzibar, stvmike (67), Leroywulf (63), Erik (60), SoCal Harley (55), drew96 (43), Reverend_d (41)
boroda's Avatar
boroda boroda is offline
Sportster/Buell Model: XL883 conv 1200
boroda is an unknown quantity at this point
Default Help me choose a map for TC88A
Greetings! I found an archive with maps on sportsterpedia but there is no description for which motorcycle configuration to use.
I have XL883 2006 converted to 1200, stock heads, stock compression ratio pistons, Andrews N2 cams, Dynojet kit for CV40 carb (45,180 jets), S&S intake, Cobra RPT exhaust. 29T drive pulley, stock was 28T
Which map is best for me?
You can always start at 2, &0, which may be recommended by Daytona Twin Tec, and by Hammer Performance. Any fine tuning from there may require usage of a Dino as there are other considerations, ambient temperature, elevation, humidity, fuel condition etc.
I.B.A.#26543,
Steamboat_Willy Steamboat_Willy is offline
Sportster/Buell Model: 1200 Roadster
Other Motorcycle Model: Yamaha Virago 1100
Other Motorcycle Year: 1998
Steamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to allSteamboat_Willy is a name known to all
The Jester series of maps are probably a good bet.
2005 Roadster 1275, 570 cams, Mikuni HSR42 carb, Supertrapp 2-1, Forcewinder intake.
Old 6 Days Ago
Highly-Dangerous's Avatar
Old 6 Days Ago
rejeanprimeau's Avatar
With Andrew N2 I would choose the Scarecrow.
Old 4 Days Ago
boroda's Avatar
Thanks! I will try them all
Old 1 Day Ago
boroda's Avatar
Friends! In some maps, I put my VSS and it does not react and the speedometer is lying, can this be the case or the map is incorrectly uploaded?
