0 Gear and brake linkage
0 Oil pressure switch
0 need help with 68 XLH
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
Old 28th February 2016
xldukes xldukes is offline
Sportster/Buell Model: xl883c
Other Motorcycle Model: Harley Street Rod
xldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond repute
Default Hammer 90"
Aaron and I spent the day tuning of my dragbike. I had my carb modified over the winter so there was a learning curve on tuning it. Heres how we ended the day.
lugster's Avatar
lugster lugster is offline
Sportster/Buell Model: xl883r
lugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond repute
SWEEEET!! Better get some Velcro.....
rocketmangb's Avatar
AH Holy Shit !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Whats up with the choppiness down stairs ?
it doesn't run well there
Almost looks like a 2 step limiter !
lugster's Avatar
sportytrace's Avatar
OzChick
Sportster/Buell Year: 08
Houston, we have lift-off. That should be a helluva buzz!
Bulpitt's Avatar
Bulpitt Bulpitt is offline
Sportster/Buell Model: XLH HAMMER 1250
Bulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud of
Good Lord!!!!!
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
Nice job, That's a great baseline, looking forward to see what it want's at the track. Cool stuff, good info, Thanks for sharing.
