0 Carb ???
Last Post: andy2175m4
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
ironhead, xlch
Old 17th May 2016
Ltdr13 Ltdr13 is offline
Ltdr13 is an unknown quantity at this point
Thumbs up 1974 Ironhead sportster xlch
Just picked up a 74 Sportster with 9626 miles and a shovelhead tank that turned out bad once I removed the old paint, but before that I never had full throttle, went through and made sure the carb was clean its a zenith and then adjusted the points and timing and then the tank issue so I am not sure if its been fixed just yet. Ordered a new tank that should be here friday so now im just cleaning and setting up other things on the bike.
https://imgur.com/gallery/KO1nf
Old 17th May 2016
jeffro57 jeffro57 is offline
Sportster/Buell Model: custom
Sportster/Buell Year: na
jeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud of
flush out the fuel lines as well, many forget to do that, (uh including me) petcock as well
Old 17th May 2016
Fresh tank and lines incoming. Hope to have it running again this weekend.
Old 17th May 2016
MXHD55U MXHD55U is offline
Sportster/Buell Year: 1969
MXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant future
so what was wrong with the XLS tank on the bike?
MX
Old 17th May 2016
snow snow is offline
Sportster/Buell Model: xlch sportster
snow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant future
Nice bike. Looks fairly unmolested.
Old 19th May 2016
Yeah its a little dirty but over all a very good find I think. The shovel head tank had a crap paint job so I removed the old and found about 50 pin holes and a baseball sized dent that had been bondo'ed over. Oh well I get a 4.2 gallon with almost the same shape today.
Old 19th May 2016
A 4 gal tank is too big for a sporty.
Guys talk about range but a 3 gal tank will get you well over 90 miles.
Your keister will need a break at 75 miles. If you are traveling through a dead zone and need extra fuel there are camping fuel bottles or even yard machine fuel sold in quart/liter cans.
I like the camping fuel bottles, more impact resistant.....
Old 19th May 2016
I'll see today, if it looks too fat I'll send it back but either way I'm just happy to keep moving it forward.
Old 20th May 2016
https://imgur.com/gallery/gpjfk This is the new setup. Oh and I re adjusted the points and have full throttle also. Now to paint so I can ride this thing for real for the first time.
Old 20th May 2016
LTD
be sure to check the front turn signals don't make contact with the tank on full lock
that's often a problem
MX
