0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 20th May 2016
night-train night-train is offline
Sportster/Buell Model: modded XL883/1250
Sportster/Buell Year: 97
Other Motorcycle Model: FLHTCU
Other Motorcycle Year: 2008
night-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to behold
Default NHRS 883 to 1250
NRHS 1250 cylinders
Hurricane pistons for Lightning Heads 10.5:1
Stage 2 Buell Lightning heads
Andrews N4 cams
Hurricane intake w/ KN filter
Dyna 2000i set for single fire 7K rev limit
SE slip ons
Stock 883 gear box and final ratio
