5 How do I increase sag ?
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 21st May 2016
rocketmangb's Avatar
Default Dyno Shops in SoCal
The guys in SoCal visited Fuel Customs in Pomona,Ca on Friday for some Dyno testing.
4 Sporties made 67 pulls over 8 hours !
Good guys and the price was fair.
I recommend them for you locals.
http://www.fuelcustoms.com/contact/
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
